Epson Home Cinema 3010 projector - Blue glow bottom right of screen - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2014, 05:40 PM - Thread Starter
project1973's Avatar
Any ideas regarding the blue glow on the bottom right corner of the screen? It's much worse when the projector turns on, but it remains present all the time. Its very noticeable while watching a black and white film or if there is a lot of red/yellow in the shot. It has only been like this for 3-4 weeks (projector is 7 months old).
Has anyone encountered similar issues? If so how did you fix it (if you did)
Thanks in advance!
project1973 is offline
Old 10-15-2014, 12:23 AM
ShawnSteele's Avatar
Question
Thanks in advance!
Mine just started doing the same thing, same place. Did you figure it out? I assume it's maybe the bulb? Other possibilities seem worse. Mine's way older though.
ShawnSteele is offline
Old 10-15-2014, 12:38 AM
action_jackson's Avatar
Quoted: 321 Post(s)
Liked: 108
Mine does this during startup, not sure what is causing it but it goes away after a few minutes. I had mine for over 2 years before I ever noticed it doing this. This is on a relatively fresh second bulb.
Every LCD projector I've owned has had a problem with blue tinge around the edges over time.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is online now
Old 10-15-2014, 12:40 AM
Every LCD projector has had a problem with blue tinge around the edges over time.
Hmm, so its not the bulb, might be the LCD itself? That's a bummer.
Old 10-15-2014, 02:34 AM - Thread Starter
I never fixed the blue glow issue, Epson said it was a faulty panel. If your projector is still under warranty they will send you a new one - - they were pretty good about it. Good luck
Old 10-15-2014, 02:36 AM - Thread Starter
If it goes away after few minutes I wouldn't worry about it.... But it could lead to a permanent glow - - if so get it replaced.
Old 10-15-2014, 03:34 AM
Quoted: 321 Post(s)
Liked: 108
Unfortunately mine started, or I first noticed it, after my warranty and extended warranty had expired. I have not been too worried about it since it goes away after the projector warms up. I'm just hoping that it lasts until I can afford a laser projector.
Old 10-15-2014, 06:54 AM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Just curious--how many hours did you guys have on your 3010s before noticing this blue glow problem? I've had mine for just about 3 years & haven't seen this yet. Of course now I'll be looking for it........ Other than the noisy iris thing (I just leave it off) it's been trouble free. I do wish I could upgrade to a 5030ub though.
Ed
old corps is offline
Old 10-16-2014, 09:24 PM
Quoted: 321 Post(s)
Liked: 108
Mine had about 5000 hours on it before I noticed it.
Old 10-16-2014, 09:28 PM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
I have the same issue on my 8500ub, except my blue tinge is across the top of my image. I suppose by the sound of it this sort of thing happens often.
d_m1010 is offline
Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020
