Epson 3010 Not supported. H:67.49kHz V:59.99Hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-22-2014, 03:13 PM - Thread Starter
krisjun's Avatar
Hello, this is my first post here so I hope I don't earn a bad rep on my first post. I have searched on here, I have searched on google, I have searched the owners manual, but I haven't been able to find any answers yet. So I decided to join this site and hopefully learn a thing or two.
So the issue that brings me here is from my Epson 3010, its extremely annoying and I hope it can be resolved pretty painlessly. While watching a movie or playing a game the screen will occasionally flash to black and then the picture will come back after a couple seconds (my BF4 k\d ratio has suffered because of this), after a few of these flashes the screen will just go black and display a little message in the lower left corner of the screen saying "HDMI 1, Not supported. H:67.49khz V59.99Hz". I have checked the HDMI cable, seems fine, I have tried multiple HDMI cables and the problem persist. I believe I read somewhere that people were getting around this issue by running a 30hz refresh rate... id rather not do that.
So does anyone have any ideas or can point me in the right direction to find an answer? Thanks ahead of time.
krisjun is offline
post #2 of 13 Old 02-22-2014, 07:36 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Sorry for your troubles. I've had a 3010 since shortly after it was introduced (late 2011) and fortunately never had a problem. Sounds like a HDMI "handshake" problem and the 1st thing I'd try would be what you've already done-try another cable. You might try HDMI 2 or if you're going through a AV receiver try hooking it up directly to the pj and use it's speakers to isolate the problem. I'd call Epson with that code its giving you and see if they can help. HDMI compatibility problems can be a major pita to figure out. Good luck!
Ed
old corps is offline
post #3 of 13 Old 02-23-2014, 08:31 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
What exactly are you trying to project? You don't give any details other than your problem.
Here are the refresh rates for the 3010 from the owner's manual.
Are you outputting from a Blu-ray player, DVD player, Cable TV box?
What are your settings? You don't say.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #4 of 13 Old 02-23-2014, 10:36 AM - Thread Starter
krisjun's Avatar
I am running HMDI straight from my gaming pc to the projector. Radeon 7990 graphics card. I am projecting everything from 1080p movies, to 1080p gaming, both 3D and 2d. I do not run the sound through my projector. 135" screen. None of the warning lights come on when the picture goes out. I have considered buying a rather expensive HDMI wire to see if that will solve the problem, but Id rather not spend a ton of money on one wire just to get the same result. The HDMI wires that I have been trying to use are 6' wires that have been provided with the multiple cable boxes I have used in the past. I am not using any kind of relay because it is only a 6' wire.
I have switched back and forth between economy mode and regular, problem still persist.
If the video card wasn't a newer card I would imagine that could be the problem, but I have tried multiple cards and still get the same results. I do find it interesting that when I use a DVI-HDMI connection I do not get the black screen issues. But I cant view 3D when using this type of wire. All video card drivers are up to date, and I have been through multiple video card drivers trying to fix this issue.
Also, I don't know if this would have anything to do with anything, but when trying to watch a 3D movie using PowerDVD, the movie looses sound\audio sync ALL THE TIME!
If there is anymore details I can give, that will help solve this issue, just let me know! Thanks for taking time to help resolve this.
krisjun is offline
post #5 of 13 Old 02-24-2014, 08:55 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
As much as I'd like to help once a HTPC is introduced into the equation my knowledge is very outdated. I recommend posting your problem in the Home Theater Computers forum. Post back if you ever resolve your problem.
http://www.avsforum.com/f/26/home-theater-computers
Mr.G is offline
post #6 of 13 Old 02-24-2014, 04:00 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
Using a HTPC can be a daunting task. You have many hardware and software vendors not all playing well together. The content providers don't want them to work and do everything in their power to add DRM to protect their content. If you use software to eliminate the DRM it will all work better (DVI is not supported by DRM that's why it works) .
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #7 of 13 Old 02-28-2014, 02:58 PM - Thread Starter
krisjun's Avatar
suggestions for a DRM software?
Has anyone else had this issue and resolved it?
krisjun is offline
post #8 of 13 Old 03-01-2014, 08:01 AM - Thread Starter
krisjun's Avatar
When I get the message saying the image isn't supported I can still go through the projectors menus, meaning the projector isn't "wigging out". I can also switch sources and the other sources show up. I purchased a new Monster HDMI cable (I know, a waste of money, but I plan on returning it anyways) and now I get different unsupported numbers, now they are H:67.49khz V:57.98hz. I should also mention that this message will pop up even if Im just projecting my Windows 7 desktop.
Here is a pick of the message.
Any ideas?
krisjun is offline
post #9 of 13 Old 03-01-2014, 08:34 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Ok, Im starting to think it isn't the projector. When I get the message saying the image isn't supported I can still go through the projectors menus, meaning the projector isn't "wigging out". I can also switch sources and the other sources show up. I purchased a new Monster HDMI cable (I know, a waste of money, but I plan on returning it anyways) and now I get different unsupported numbers, now they are H:67.49khz V:57.98hz. I should also mention that this message will pop up even if Im just projecting my Windows 7 desktop.
Any ideas?
Have you tried PowerStrip 3.9?
http://www.entechtaiwan.com/util/ps.shtm
Mr.G is offline
post #10 of 13 Old 03-01-2014, 08:52 AM - Thread Starter
krisjun's Avatar
no I haven't... but after reading what the use of this software is, im curious as to what you are thinking I might benefit from this?
krisjun is offline
post #11 of 13 Old 03-01-2014, 09:44 AM - Thread Starter
krisjun's Avatar
I just spoke with Epson and I must say the customer service is an 11 out of 10! They determined my issue was a hardware issue and is sending me a new projector. If I had any complaints it would be that they are sending a refurb and I feel like I should get a new one since I bought this one new... but maybe that's unrealistic.
Thank you Epson!
krisjun is offline
post #12 of 13 Old 03-01-2014, 11:13 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
Thank you Epson!
Epson has really good customer service. I've always been impressed with them
wormraper is online now
post #13 of 13 Old 03-02-2014, 05:34 AM
ashyt16's Avatar
Quoted: 37 Post(s)
I would use mediplayer hc for everything other than full 3d playback.
I used to have audio sync and drop out problems with an older radeon which couldn't cope with full HD movies too well.
Are you sure you are using hardware decoding and not software?
ashyt16 is offline
Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020
