Do I need lens shift? Or maybe just a different projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-24-2014, 03:50 PM - Thread Starter
bigrig's Avatar
Quoted: 24 Post(s)
Okay, so I purchased an Epson 2030 as my first projector, and it's not working out.
Here's the setup in the basement - ceiling is 9'8" tall, I would like the projector ceiling mounted 11-12' away from the screen, and a 110" diagonal image with the bottom edge around 24" off the floor.
I have the Epson dropped down 30" from the ceiling, and the image still isn't low enough as I would like when the projector is level. I tried angling and the keystone correction, I was horrified as it ate away the pixels! wink.gif Any lower and it will start getting in the way.
So I'm looking for suggestions on what projectors could meet my requirements. Looking to stay below $1300, probably.
Matt
"It's an invention, and it makes Non-Stop Rocking possible!"
bigrig is offline
post #2 of 9 Old 02-24-2014, 03:57 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
You have the projector upside down, with it set to ceiling mode correct?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 9 Old 02-24-2014, 04:07 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 196
Because of your high ceiling the 2030 has a slight negative off set so it has to be slightly below the top of the screen. The Mits HC7900DW has a very large off set and could be mounted right on the ceiling and is a steel at $800. If you need to stay with LCD the Epson 8350 is your only choice and its not 3D. The BenQ 1070 would also work as it has a slight lens shift. Anything else in that price range with lens shift would have to be used. I think the Epson 3010 has a positive off set and could be mounted 8" or so above the screen
bigrig likes this.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #4 of 9 Old 02-24-2014, 09:35 PM
AV_Integrated's Avatar
Quoted: 978 Post(s)
Liked: 721
The Mits. is a great recommendation. It's really priced quite low right now and offers a tremendous value for the money. It has a lot of offset, like 20 inches or so, which is great for your high ceilings. So, you wouldn't need to lower it nearly as much to get the image where you want it.
Research OFFSET and look at the owner's manual before you purchase to ensure this works for you the way you want it to.
bigrig likes this.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #5 of 9 Old 02-25-2014, 11:29 AM - Thread Starter
bigrig's Avatar
Quoted: 24 Post(s)
Thanks for the advice, guys. I do want to have 3D, also.
The Mitsubishi, I wonder if it will be bright enough in 3D mode - I plan on using an AT screen with gain of 1.0.
So I think I've narrowed it to three - Mitsubishi HC7900DW, BenQ W1070, or Epson 3020. I'm leaning towards the BenQ, based on price and brightness. But I want to make sure I'm reading their projector calculator correctly - it says the screen will be 39" above the floor - but there is 32" vertical lens shift - does this mean I could lower it to 7" above the floor? Any other factors I should take into consideration - maybe replacement lamp cost? Size and brightness calculations attached below.
Matt
BenQ
Mitsubishi
Epson
bigrig is offline
post #6 of 9 Old 02-25-2014, 11:44 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Matt
The BenQ W1070 has much less vertical shift range than you state. As I recall its vertical lens shift range is only 15% of screen height or for a 110" diagonal screen, where the screen height is about 54", the total lens shift range is only 0.15 x 54" = 8.1". The lowest the W1070 can be positioned (center of lens to top of the projected image) is something like 3" above the top of the screen. If you can find the Mits HC7900DW at anywhere near the price of the BenQ W1070 then the Mits would be a steal at that price as it's a much more upscale projector than the entry-level W1070. Check out the full review of the Mits - HERE.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #7 of 9 Old 02-25-2014, 12:18 PM - Thread Starter
bigrig's Avatar
Quoted: 24 Post(s)
Okay, thanks Ron. I wonder why the BenQ calculator shows 2'8" vertical lens shift...
So I guess if I got the Mits, I would just have to accept 3D movies would have to be in a fully darkened room - or perhaps try to get a higher gain screen.
bigrig is offline
post #8 of 9 Old 02-25-2014, 04:25 PM - Thread Starter
bigrig's Avatar
Quoted: 24 Post(s)
Okay, just ordered a Mits package from Amazon - give it a try and hope it's bright enough, and that we don't see the DLP rainbows!
Matt
bigrig is offline
post #9 of 9 Old 02-25-2014, 05:03 PM - Thread Starter
bigrig's Avatar
Quoted: 24 Post(s)
If we saw rainbows and needed an LCD projector with 3D and lens shift, it looks like Epson 5030 would be the solution? At $2600, ouch. Or Panasonic PT-AE8000U at $2200.
The Epson 3020 would work if I dropped it down about 30", which is do-able, but not ideal.
bigrig is offline
Epson Powerlite Home Cinema 2030 3lcd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Epson Powerlite Home Cinema 8350
