Epson powerlite 2030 on projectorcentral calculator doesn't show "ceiling" option - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2014, 02:58 PM - Thread Starter
198four's Avatar
http://www.projectorcentral.com/Epson-PowerLite_Home_Cinema_2030-projection-calculator-pro.htm
It doesn't give an option for how the projector is mounted. i.e. ceiling, floor etc?
198four is offline
Old 02-26-2014, 09:04 PM
AV_Integrated's Avatar
Quoted: 973 Post(s)
Liked: 718
Because it doesn't. Doesn't matter, it can be ceiling mounted just fine. Read the review or the owner's manual for offset information. If a projector does not have a 'known' offset or if the offset doesn't work with the calculator, or the projector has lens shift, then the projector defaults to the 'middle' of the screen. This is NOT accurate and you must read the manual or reviews to determine the offset. The 2030 has -8% offset. So, when ceiling mounted, the center of the lens must be 8% of the image height below the top of the screen. So, if the screen is 50" tall, the center of the lens must be 4" below the top of the screen. If the screen is 8" from the ceiling, the center of the lens would need to be 12" from the ceiling. This is very unusual for projectors. Most need to be several inches (or more) above the top of the screen.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 02-27-2014, 10:12 AM - Thread Starter
198four's Avatar
What kinda projector doesn't have a ceiling mount? :-s
But I don't think i understand your post properly...i am not a techie at all so much of what u said just went over my head. Will i be able to mount this projector and adjust screen settings through the manual as i normally would? :-s
198four is offline
Old 02-27-2014, 07:20 PM
Quoted: 973 Post(s)
Liked: 718
The projector can be ceiling mounted and must be mounted properly to hit the screen accurately. If you are unaware how to properly mount and setup a projector, then you should not buy a projector until you get the idea of how to do so. People often get screwed when they realize that the projector they just bought won't actually work the way they thought it would because they didn't ask questions and didn't read the owner's manual.
Lens Offset: Distance between the center of the projector lens and the top of the screen (when ceiling mounted)
Lens Shift: The ability to adjust the optics (lens) of the projector to shift an image up/down and perhaps left/right, so it hits the screen properly (not all projectors can do this)
What else didn't you understand, because you really should understand these basics before any projector purchase.
Epson Powerlite Home Cinema 2030 3lcd Projector
