Is the projector calculator for Optoma HD131xe on projector central accurate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2014, 07:26 AM - Thread Starter
198four's Avatar
Hey everyone. I have a basement that's about 28'. I wanted to get a 125" diagnoal image out of my HD131xe and i installed it at about 25ft distance. But according to Projector central calculator, you only have to install it at 10' to get that big of an image? How's that possible? I will get same size image if i move it to 10' from 25' away? !
198four is offline
post #2 of 4 Old 03-05-2014, 07:29 AM - Thread Starter
198four's Avatar
198four is offline
post #3 of 4 Old 03-06-2014, 07:55 PM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
Didn't we go over this already in another thread?
Yes it is very accurate. At least for the model you have.you are looking at the wrong number. It is 10" offset not 10' viewing distance
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #4 of 4 Old 03-06-2014, 07:57 PM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
I'm not sure at all what you are saying.
With the HD131xe, if you are using a 125" screen, then the lens MUST be between 13'7" and 16'3" from the screen and must be 10" above the top of the screen. The calculator shows you exactly that when you set your image diagonal to 125"...
http://www.projectorcentral.com/Optoma-HD131Xe-projection-calculator-pro.htm
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Optoma Hd131xe Dlp Projector 3d
