BenQ W1080ST Firmware Questions THANKS! - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 46 Old 03-11-2014, 10:03 AM - Thread Starter
Yabizar's Avatar
Refer to the 3rd post in this thread
Yabizar is offline
post #2 of 46 Old 03-14-2014, 05:50 AM
Truck0590's Avatar
i would also like to know this. i got my projector ariund christmas time. firmware version is 1.02
truck
Truck0590 is offline
post #3 of 46 Old 03-14-2014, 06:28 AM - Thread Starter
Yabizar's Avatar
Hey man, i just updated mine to 1.05 (Latest Version)... you can pay and send in your benq to get updated... but they charge you... I did it myself its actually really safe. Here are the steps and yes its a big update gives lots of 3D Options and faster loading times!
I have added a link to a Rar i have made to keep these files all together and alive. Just download and extract, this has every file you need for the 1080st.
http://www.mediafire.com/download/91...ctor_setup.rar
After you have those files do these steps
You will need a Mini USB Cable to go from your BenQ w1080 and the other end to your PC. the cable looks like this
Make sure you have that cable or you can not go any farther.
STEPS:
1. Write down all your settings before starting an update. (If you do not you will loose all your settings they will be back to default)
2. Create a new folder on your desktop called 1080 firmware (So you know what and where the folder is)
3. Download the files i mentioned Above (W1080ST V105.rar, and FlashDeviceParameters.txt, and Download_Tool.rar)
4. Place the all the Files from step 3 into your 1080 firmware Folder that you made, Extract the w1080st.rar and the download tool files.
5. After the files are extracted, go into the new DDP442x Folder that is there. Install DLP Composer onto your pc.
6. Copy and Paste your Flash Device Parameters. txt file to the DLP composer program folder (It is under programs x86 DLP Composer on your C drive.)
7. Open the DLP Composer tool and go to edit, preferences, when the window opens go to communication and set it to USB and hit Ok.
8.Now on your left select Flash Loader, Select it, a box will open just hit ok.
9. In the new box, SELECT COMPLETE IMAGE DOWNLOAD, SKIP BOOT LOADER AREA MUST ALSO BE CHECKED, Also BESIDE SKIP BOOT LOADER AREA YOU MUST HAVE 32KB Selected!!!!!!!
10. After that, where it says Flash Image File, click Browse. Go to your w1080 firmware folder you made and select your W1080st Disc Image File (This is a file that you would have extracted previously in step 4.)
11. Turn Your BENQ W1080 Projector on, let it boot up. Insert the USB cable in your pc and the min plug into the projector. (Wait for the drivers to load. This should take a minute with windows 7 or 8, it should install drivers)
12. After the drivers install, Turn Your BENQ W1080 Completely Off (let it cool then unplug from wall)
13. After it is off, Turn it back on while it is Still connected to your PC but this time while turning it on, Keep the power and auto buttons pushed down while you plug it in. (YES HOLD DOWN THE AUTO AND POWER BUTTON WHILE PLUGGING IT INTO THE WALL)
14. Your projector should have a Red Light (where it usually is orange) this means it is in download mode (ALMOST DONE!) (If the light is still orange unplug projector and hold the keys again while turning it on until they are RED) Very Important!
15. Go back to your DLP COMPOSER SCREEN and Hit the Reset Bus and Start Download. The upgrade process should take about 5 minutes. A timer will start telling you how long it will take. (Do not unplug anything during the process. When everything completes the LED on the projector will turn to standby orange.) When it is back to orange you are all done, you may unplug your usb cable and power on your projector. Enjoy 1.05
MAKE SURE STEP 9 And 14 Are setup right or you could break your projector. Just follow steps and you will be fine!
Yabizar is offline
post #4 of 46 Old 03-14-2014, 09:03 AM
DarthVaderXXL's Avatar
Hi Yabizar,
great.. thanks for the new firmware.
2 little questions i have...
1) do you have a changelog to see what is new ?
2) Do I need to flash from 1.03 to 1.04 first or can i go from 1.03 to 1.05 without 1.04 ?
Thanks for answers...
Cheers Vader
DarthVaderXXL is offline
post #5 of 46 Old 03-14-2014, 10:16 AM
Truck0590's Avatar
Yes, what does 1.05 give you? And as Vader asked can I skip versions and go from 1.02 to 1.05?
Truck
post #6 of 46 Old 03-14-2014, 12:50 PM - Thread Starter
Yabizar's Avatar
Originally Posted by DarthVaderXXL View Post
Hi Yabizar,
Cheers Vader
Question 1:Problem-1- To improve the flickering when smart ECO mode + dynamic setting
Problem-2- To add “Background” color in OSD
Problem-3 When at low temperature environment, fan oil would become thickened, cause rotational speed of
fan can’t reach target then shut down.
Problem-4- Keystone bug: When playing 3D (Frame packing), and then switch to 2D, and keystone value
can’t be kept.
Problem-5- ISF setting cannot be saved
Problem-6- compatibility problem for some unique 3D DVD players(Philips)
Problem-7- OSD Swedish language of ”on& off” wrong translation
Fixes:
-1- Hg bridge problem symptom: can’t turn on a projector, but NDF after transportation; few cases found in BQC.
There is Hg (Mercury) in a lamp bulb. Whenever the liquid mercury make the Short-circuit of electrodes of the lamp, the unit can’t
be turn on. To change the cooling status and lamp ignition behavior can make mercury condense at different locations of a bulb.
Due to Hg (Mercury) changing the location in lamp bulbs during transportation, it will be NDF in ASP.
-2- To improve power-on while system initializing
-3- To improve Philips DVD compatibility issue(BQC)
-4- Add 3D format as appendix
-5- Adjust Audio Curve for BQjp
-6- Japanese OSD correction for Cool and Warm (BQjp)
-7-To enhance HDMI searching speed
-8- To update RC code for new remote RCV011
-9- To modify the gain value to improve HDMI signal searching ability
-10- To add model name W1250 in Factory OSD (only W1070)
Added support for 3D formats:
1280x720p@59/94/60 Hz -- SBS added
1280x720p@50Hz - SBS added
1920x1080p@23.98/24Hz - SBS added
1920x1080p@59.94/60Hz - Top Bottom - added
1920x1080p@50Hz - Top Bottom - added
ISF Night setting can’t be keep after 2D->3D timing changed
To keep lamp hour after “reset all setting in USE OSD”
To improve the 32 gray level via PS3 HDMI
Modify picture mode of “power off” icon
Modify HSG setting in No signal condition
Those are just the fixes in 1.3-1.4, version 1.5 i could not find patch notes on....
2nd Question- YES i went from 1.02 to 1.05
DarthVaderXXL likes this.
Yabizar is offline
post #7 of 46 Old 03-14-2014, 01:02 PM - Thread Starter
Yabizar's Avatar
I also would like to note, during this process my 1st time, When i got to step 15 and I hit the Reset bus and clicked Start download i receieved an error.  This terrified me at first hahaha... then i had alot of googling to find out what went wrong (no my projector was fine!) It was a problem with my desktop not installing the drivers right for my projector (this made my pc not communicate with the projector to start the download mode).
If you guys have the same problem, most likely you wont, but if you hit start download and you get some weird error message its probably the same thing.  How i fixed this was I used my laptop instead and everything went 100% fine with the same exact steps.  Some people have had issues with their PC's installing the drivers right.  Just a case to case thing, everyone's pc is differnt.  Im not sure why my pc didnt communicate with my projector, I have a very very nice pc.
Anyway just wanted to post this in here incase this happens to anyone else and they still want to upgrade and are not sure what to do.
Yabizar is offline
post #8 of 46 Old 04-10-2014, 08:59 AM
gamermwm's Avatar
Quoted: 84 Post(s)
Liked: 93
I also went from 1.02 to 1.05. Everything went smoothly. As long as you aren't in a hurry and look over things twice before you start the download - you can't go wrong. I figured I would be the LAST person to attempt this but I finally did. Your directions here were simple and the easiest to follow. Nearly foolproof.
-Mike
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #9 of 46 Old 04-19-2014, 07:33 AM - Thread Starter
Yabizar's Avatar
hey wanted to say thanks! the guide i went off was good but a little confusing (i think the person was not from America or English. So i tried to make it as simple as possible!
gamermwm likes this.
Yabizar is offline
post #10 of 46 Old 04-26-2014, 12:14 AM
gunmasterg9's Avatar
Was a bit skeptical as this is my first projector and didn't want to end up ruining it, however the steps provided by Yabizar could not been more simple.
If you read it word by word and do as it says word by word you cannot go wrong.
Wont really know the full extend of changes until i try it later however the thing  that I have noticed initially, going from version 1.02 to 1.05, is that it boots up and shuts down alot quicker.
Anyone know how we can do the ISF calibrations ourself without having to pay someone?
gunmasterg9 is offline
post #11 of 46 Old 04-27-2014, 02:38 PM
Having done the upgrade I have noticed another thing with the new firmware. The focus over the whole screen is a lot more sharper. I used to find if I focused on the center the corners would be out of focus slightly. Don't know how but it seems to be sharper not only in the center but in the corners.
post #12 of 46 Old 04-28-2014, 07:04 AM
gamermwm's Avatar
Quoted: 84 Post(s)
Liked: 93
Yes and I agree with others who have said that Cinema mode is now darn near perfect AS IS, no need for calibration (just don't use brilliant color here or you'll see colors/contrast shift to less than ideal)
gamermwm is offline
post #13 of 46 Old 05-04-2014, 09:40 PM
rudi77's Avatar
Im nothing upgrade my Benq 1070.
Win8 usb driver problem!
Only winxp usb drive upgrade?
rudi77 is offline
post #14 of 46 Old 05-07-2014, 11:56 PM
Having the upgrade for a few weeks now and watching various material the other thing I have noticed is the 3D is better. Bearing in mind the only 3D option I have is sky 3D. Initially when I tried the 3D It wasn't impressive but I put that down to the glasses as I didn't want to pay the high £80 benq want for their official glasses and bought a cheap £20 pair of universal glasses off Amazon. I'm not a huge fan of 3D so it's not something I watch all the time as it gives me a headache but I am sure the picture is sharper, less ghosting and handles motion better in 3D then previously.
post #15 of 46 Old 07-10-2014, 07:13 AM
Liked: 0
I have a question to you, i would upgrade my 1080st. But i cant get to download mode. plugged off from power cord, holding power+auto plug in, and led turns green and beamer boots up. whats going wrong
Markus Müller is offline
post #16 of 46 Old 07-10-2014, 10:54 AM
Liked: 0
the solution was this manual: ftp://62.141.76.120/driver/projector..._procedure.pdf
it is for firmware 1.02
post #17 of 46 Old 07-13-2014, 06:06 PM
Liked: 0
Anyone havin problems with the projector gettin stuck in download mode? Any solutions to get it back in normal mode? It won't get contact with my pc, even tho it's stuck in the download mode...
Hammy89 is offline
post #18 of 46 Old 09-05-2014, 02:49 PM
baux's Avatar
does someone have a working download link or the file itself?
the ftp site is not connecting anymore..
baux is offline
post #19 of 46 Old 09-12-2014, 08:12 AM
Liked: 0
Hi, baux.
Thanks for getting in touch.
No luck here, I'm afraid.
I'll let you know if I hear anything.
All the best,
smackenz
smackenz is offline
post #20 of 46 Old 09-24-2014, 03:45 PM
Liked: 0
I am not able to get into the link either. Anyone has another link for this?
clownfish360 is offline
post #21 of 46 Old 09-26-2014, 09:29 AM
shepd's Avatar
Liked: 0
I'd also love to get a copy of the firmware, but the username/password for the FTP doesn't work.
shepd is offline
post #22 of 46 Old 09-27-2014, 11:04 AM
darrin0's Avatar
FINALLY!!!!! After hours and hours of searching I found on a website in some other language a working username and password to download the benq w1070 or benq w1080st firmware. (same ftp site as posted above, but new and working username/password)
ftp://62.141.76.120/driver/projectors/W1070/
ftp://62.141.76.120/driver/projectors/W1080ST/
login: User
password: pass2005
spaceman763 likes this.
darrin0 is offline
post #23 of 46 Old 09-28-2014, 12:04 PM
Liked: 0
Thank you darrin0. Been searching for this for over a month now.
I've updated my Benq W1080ST from 1.02 to 1.05 using firmware file "Projector_fw_W1080ST_20140916_105829_W1080st_v105_ 6235_NEW.rar". There are three firmware files in the ftp address. This appears to be the latest.
Cheers
spaceman763 is offline
post #24 of 46 Old 09-28-2014, 02:20 PM
shepd's Avatar
Liked: 0
A huge amount of thanks for that, I've made sure to get a copy for my projector!
shepd is offline
post #25 of 46 Old 10-02-2014, 04:33 PM - Thread Starter
Yabizar's Avatar
Hey sorry guys i havnt checked back in a while. I did not know my link was dead. I also have a backup of the files. I added a rar file with everything you need in the 3rd post. Enjoy
smackenz likes this.
Yabizar is offline
post #26 of 46 Old 10-12-2014, 04:13 AM
Liked: 0
Thanks for updating the link. Really appreciate it.
smackenz is offline
post #27 of 46 Old 10-12-2014, 10:11 AM - Thread Starter
Yabizar's Avatar
Cool
Anytime man!!
Yabizar is offline
post #28 of 46 Old 11-18-2014, 08:36 AM
lilcheeks's Avatar
Originally Posted by Yabizar View Post
Anytime man!!
Any chance you could update the link one more time? I can't seem to find the file anywhere. The other areas on the forums have FTP's with passwords that no longer work. If anyone can link the file, that would be great!
lilcheeks is offline
post #29 of 46 Old 11-18-2014, 06:18 PM - Thread Starter
Yabizar's Avatar
give me a few and i will reupload it...i cant seem to find a site that you can upload files for an extended period of time.
Yabizar is offline
post #30 of 46 Old 11-19-2014, 04:28 PM - Thread Starter
Yabizar's Avatar
Its uploading now, i used mediafire i made an account and everything so this should stay up way longer. Sorry for the links breaking guys. I am trying everything i possibly can! New link will be posted back at the top of this thread. its 60% done
Yabizar is offline
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
