LG HX300 DMD chip replacement - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 3 Post By erdi01
  • 1 Post By IP-Man
  • 2 Post By erdi01
post #1 of 9 Old 03-28-2014, 08:34 AM - Thread Starter
erdi01's Avatar
Quoted: 13 Post(s)
Liked: 26
Hi there,
after 4 years of use, my LG HX300 begins to show white pixels. So I opened the body to see what kind of DMD chip is built in there. It is called 1076E6038B. Since I don't want to replace it by a chip, that also fails in a few years, I wanted to replace it by a newer, perhaps less error-prone production series.
Does anyone know, which type designation would also fit to my beamer? The only thing I can see from the type designation is the resolution. 1076 seems to stand for 1024x768. Do you think the DMD type 1076-6039B could replace mine? Or even the one with a higher resolution 1280-6038B, which might have 1280x800 pixels?
Many thanks in advance.
Thomas
erdi01 is offline
post #2 of 9 Old 03-31-2014, 11:18 AM - Thread Starter
erdi01's Avatar
Quoted: 13 Post(s)
Liked: 26
Does anybody have any experiences with DMD chip interchangeability?
erdi01 is offline
post #3 of 9 Old 06-05-2014, 10:42 PM - Thread Starter
erdi01's Avatar
Quoted: 13 Post(s)
Liked: 26
Here a picture of the DMD:
alperinho, masum naqvi and andi030 like this.
erdi01 is offline
post #4 of 9 Old 06-06-2014, 05:01 AM
IP-Man's Avatar
Hi,
I have no experience with replacing DMD chips. But I had a similar problem when I pulled the chip from my old projector. My chip had a bad contact or short circuit caused by the thermal grease splashed on the contact pins ( due to careless removal smile.gif ). After careful cleaning with alcohol white pixels disappeared. I think it is worth to check for bad contact because it will come out much cheaper than replacing the chip.
andi030 likes this.
IP-Man is offline
post #5 of 9 Old 06-17-2014, 12:16 PM - Thread Starter
erdi01's Avatar
Quoted: 13 Post(s)
Liked: 26
I successfully replaced the DMD with a new 1076-6138B from China.
Best regards
Thomas
alperinho and andi030 like this.
erdi01 is offline
post #6 of 9 Old 06-19-2014, 05:08 AM
Liked: 0
Hi Thomas! I have exactly the same problem with my LG HX300G: black and white pixels all over. Could you tell me where you ordered your new DMD chip and what the difference between the original 1076E6038B and the new1076-6138B is? Was the replacement difficult?
Regards
Alper (Germany)
alperinho is offline
post #7 of 9 Old 10-14-2015, 02:36 PM
Liked: 0
power issue
My HX300g is not powering on. i tested the power supply with multimeter. The circuit is broken somewhere. I opened the top cover but i can't get the whole unit out. I did not try to apply force. Do i need to take the top metal part with buttons off?
masum naqvi is offline
post #8 of 9 Old 10-14-2015, 02:45 PM
Liked: 0
I am trying to open the projector. power supply works. how to remove the housing??
post #9 of 9 Old 11-06-2015, 01:11 AM
Liked: 0
Having the same issue here. Did it had to be solded it? or just chiped in?
Where did u get urs? saw some at ebay (from USA ) for ~100€ (which is hardly worth it!)
Did u try a resolution upgrade?
andi030 is offline
