projector advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 04-07-2014, 08:54 PM - Thread Starter
SDB553's Avatar
hello,
ive never used a projector before, and know nothing about them. right now i have a vizio 55" LED, and while it's fine, something about the idea of watching a movie on a 90"+ screen just seems appealing.
what i'm wondering is, is it possible to get a projector that would rival my LED TV for under $2000? If not, how much worse would it be?
Could anyone give me some suggestions on what a good sub $2000 projector would be?
also, I would need to purchase a screen I suppose. my walls are a light beige color and i'm assuming that wouldnt work too well for a projector.
my viewing distance could be between 8 and 10 feet.
thanks
SDB553 is offline
post #2 of 34 Old 04-07-2014, 09:02 PM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
Originally Posted by SDB553 View Post
hello,
thanks
with that short of a thow... I'd suggest the Benq W1070... or the 1080... that will give you a nice big picture for that short of a throw.
as for a vizio 55 LED.... you won't be AS crisp as a 55 incher as long as your vizio isn't years old but the overall picture quality will blast your vizio out of the water.
another suggestion is LIGHT CONTROL.. and we don't mean turning off all lights and blanking out the windows.. that light biege color will play hell on your blacks and wash out the colors as well. a dark matte color is best for HT (matte black is the best, but a lot of other darker colors will work well too). I had white walls and I guarantee you that it made a HUGE difference in my viewing when I darkened those walls and ceiling
other factors we haven't asked yet
1. what's your room dimensions
2. what type of room is it (living room, dedicated room etc
3. what type of light sources do you have in the room (windows, ceiling windows etc)
wormraper is offline
post #3 of 34 Old 04-08-2014, 04:54 AM - Thread Starter
SDB553's Avatar
thanks.
the room is my living room. my living room kitchen and dining area kind of flow together. With my couch against the back wall, on the right wall is patio doors, which is about 14 foot long. Front TV wall is about 12 foot, then breaks into an area where the bedroom and bathroom are. The wall behind me that flows into the dining area is about 28 foot. i'll post a diagram of the apartment i live in when i get a chance.
and yes, from what ive read, the beige walls might not be good. this is why i'd look into buying a pull down projector screen. not sure what i can do about darkening the ceiling, as the landlord probably wouldnt want me painting the ceiling...but a screen, i can do.
there is one crazy idea ive been toying around with...i live in a one bedroom apartment. what ive been thinking of is this. removing the bed from my bedroom and placing like a futon/pull out type of bed there, and then getting a couple of recliners or theater seats, put my surround sound system in there, and a screen and projector. This way, I could have a dedicated theater in my apartment, and still have a bedroom...lol. thoughts?
SDB553 is offline
post #4 of 34 Old 04-09-2014, 04:35 PM - Thread Starter
SDB553's Avatar
ive heard of the BenQ W1070 and 1080 before. ive also looked online and found that there are several projectors that are 1080 for under $2000. Problem is, ive heard that in order to get a comparable projector to a TV, you'd have to spend a lot more money.
The question I asked one day was, i was looking at a 51" plasma that was about $700. I posted on a forum and the response was that, I wasn't going to be able to buy a projector that would touch a $700 plasma for under $2000.
So, having said that, is there a formula or something that would help you gauge a projector? such as, if I spend $x to buy a LED or plasma TV, then i'd have to spend $x to get a comparable projector.
In my case, I bought a 55" Vizio LED for $698. If I were to want to buy a projector that had the same image quality, how much would I have to spend?
SDB553 is offline
post #5 of 34 Old 04-09-2014, 05:00 PM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
that's a hard one to estimate.. but I'd say something along the lines of JVC RS46 or Sony 55ES would do quite nicely and if you're on a budget the Epson 5030 would get your really darn close
without know what model and what your specs are on the TV it's hard to say. the Benq w1070 is a great projector with great colors, but it's black levels are "introductory". however, I have an LG 55 inch LED and I have to say that my epson 8350 (which is very comparable to the w1070) was VERY close in terms of picture quality, but not AS good.
post #6 of 34 Old 04-09-2014, 06:19 PM
umairsemail's Avatar
I doubt your landlord would let you drill holes in the wall. All projector screens require this except a pull-up projector (from the floor).
umairsemail is offline
post #7 of 34 Old 04-09-2014, 06:22 PM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
I forgot he was in an apt.. I'd recommend a Benq W1070 then. the increased contrast and black levels aren't as easily recognizable in a non light controlled room
and drilling holes... pfffft, that's what spackle is for... I drilled all over my old apt...
post #8 of 34 Old 04-09-2014, 06:45 PM
How would you go about blanking the windows though? I have a new room extension, 20x15, that has only one line of three windows and would like to know the best way to blank em out lol.
I don't know if a projector is a feasible option for this guy. He obviously can't paint his walls, can't watch with any ambience unless he's willing to buy expensive screens, and has to stick to a floor screen (very odd) cuz the rest will make holes in the wall.
post #9 of 34 Old 04-09-2014, 06:48 PM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
I'd use black out curtains... usually can get them pretty decently priced... will kill all outside light pretty easily and can be put over regular blinds/curtains... plus they'll have an added benefit of keeping out heat.
post #10 of 34 Old 04-09-2014, 06:49 PM
Sonyad's Avatar
Quoted: 152 Post(s)
Liked: 86
You can also use a tripod screen.
Sonyad is offline
post #11 of 34 Old 04-09-2014, 08:46 PM - Thread Starter
SDB553's Avatar
I have a vizio E550I-B2. As far as drilling holes, the landlord says that you can drill holes in the walls, im sure the rule is to not get carried away, and they will be repaired when I move out.
Also, the tripod screen is also an option.
apartment1.jpg 20k .jpg file
apartment2.jpg 85k .jpg file
This is the layout of my apartment. The only windows are the windows on the doors leading to my patio, which have full blinds over them. They are on the wall to the right of my love seat. At night, light seeping in isnt a problem.
frys sells several different projector screens that range between 84" and 120" some are screw in, some are tripod style, or i could look at something like this: http://www.amazon.com/Elite-Screens-100-Inch-Projector/dp/B000YTRFEG/ref=sr_1_1/180-7407100-7571248?ie=UTF8&qid=1397100916&sr=8-1&keywords=home+theater+projector+screens
or this?:
http://www.amazon.com/Elite-Screens-F120NWH-ezCinema-Projection/dp/B001N2N6U0/ref=sr_1_6/180-7407100-7571248?ie=UTF8&qid=1397100916&sr=8-6&keywords=home+theater+projector+screens
one question though, someone mentioned that projectors cant project black color, so, if you have a white screen, how do you end up getting black colors?
what is the difference between the BenQ 1070 and 1080? Both are pretty close to the same price.
however, from what im seeing of the options you listed, it's looking like i would have to spend upwards of $3000 to get a comparable projector. The sony and JVC you listed were about that price. The epson 8350 and the BenQ projectors would be more along my price range, but, seems like i'd be better off spending $1500 on a good LED TV than a projector. Would this be correct?
ID:	77151   Click image for larger version
SDB553 is offline
post #12 of 34 Old 04-09-2014, 09:22 PM
Rarshaiz's Avatar
Personally I think your over thinking this quality thing. I have a 60" Sony TV. I can tell you with out a doubt I would much rather watch a movie on my Benq W1070 projector then on that led TV. But then again I am watching my projector on a 135" screen.
One thing the projector will do your $700 Vizzio won't do is 3D.
Another thing to keep in mind when stepping up to a projection is this. The bulbs are not cheap by any means. Though not as bad as they used to be. So dont do what a friend of mine did and watch normal TV on it every day.
I have seen the 1070 for less then $800 at Fry's if you have one near you go in store to get a price, as the speakers I bought were $80 less in the store then their online price was listed at.
I once paid $4000 for a projector and after getting my 1070 I can guarantee you I will never spend that amount of money on a projector again.
But that is just my opinion.
Forgot to mention do not buy a screen right out of the gate. Play it on your wall first then go to some place where you can view it on a screen then decide if you want to spend the extra money on a screen. Screens are easy to buy but depending on where you get it, it can be a pita to return.  I have seen projection on flat grey walls, white walls, and white textured walls and now on my screen. The only reason I have a screen now is because the room I have my projector in has 3 windows and the screen goes over the 3 windows other wise I would have projected it on a wall with most likely flat grey paint, which the rest of the room was painted with.
My experience with BenQ customer service is the reason I have now purchased a second BenQ projector. The first projector I purchased worked for a day and then it stopped working. I called BenQ and they had me a new one 2 days later on my door step. No hassles no headaches.
Ftoast likes this.
Rarshaiz is offline
post #13 of 34 Old 04-09-2014, 09:39 PM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
agreed. you're over thinking it. a projector won't match an excellent TV except in the really high prices, but they'll come REALLY close, and the extra immersion of a 100+ inch screen is unbeatable.
btw, the 1070 and 1080 are almost identical. the 1080st is a short throw projector and can give you a large picture projecting from 5 feet or so vs. the 8-10 feet of the w1070... but unless you want a 140 inch screen or something the 1070 will do you fine.
especially with you living in an apt like that, the JVC and Sony LCOS models are great and will give you a serious leap in quality, but only if you have a room that you can light control with dark walls etc... in a light colored room the Benq, optoma or epson 3020 will do just FINE.
post #14 of 34 Old 04-10-2014, 08:08 AM
Ftoast's Avatar
Quoted: 1725 Post(s)
Liked: 549
The projector shines colors so brightly that your eyes adjust to the light and see the spots that aren't being projected on as black. Most DLPs (and LED/LCD TVs) around this pricerange have a native-on/off contrast ratio around 2000:1 which is the same as a well setup movie theater. This means white is 2000X brighter than the darkest black this projector can get to because it's nearly impossible for any projector (or LED/LCD TV) to block every bit of its own lightsource. So a w1070 that is set for lighting a surface with 2000lumens of peak power, is still hitting that surface with 1 lumen when it's showing black..so depending how dark your room is; if a curtained window is letting 1lumen of light or less sneak through onto your screen, you won't really notice a difference. If that curtain is letting more light onto your screen, your darkest available black is now higher than the projector's natural black and is lowering your contrast ratio. If you lower your contrast ratio enough, your picture will look bad and washed-out.
The important thing to remember is, darker shades of plain paint absorb all light equally. So. A white wall reflects 100% of the light hitting it to look white. A medium grey wall only reflects 20% of light hitting it, so it looks darker..grey. That brighter (5 lumens) light coming through your curtain is only reflecting 1 lumen off your grey wall, BUT the 2000lumen maximum from your projector is only able to reflect 20% as well..so it only looks like 400lumens which still leaves you with the exact same contrast handicap, AND a darker overall picture.
Specially reflective paints/screens can redirect light so projector lumens shine toward your seating positions whilst light sneaking through a side-window gets reflected to the opposite side of the room. These special paints need to have very narrow viewing-angles to do their job properly, and that means sitting too far to the sides of your couch will show a much dimmer picture than the center seat AND sometimes the outside edges of the screen will be noticeably dimmer than the middle.
Plain/flat paint is much easier and more forgiving to deal with. And darker shades won't improve contrast, only darken your entire image. This is why the cheapest, easiest and best solution in most cases is to go with a white screen and a few pair of $20-30 curtains.
Simple <$250 dedicated black-fabric theater room, build in a day, takedown in an hour.
Easy $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
"A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #15 of 34 Old 04-14-2014, 04:54 PM - Thread Starter
SDB553's Avatar
I went to a home theater store over the weekend and they had an epson. I cant remember if it was the epson 8350 or the 2030 (or 3020?). Anyway, it was around $1500 if i recall. I must say, the image looked very good. The colors were bright and vibrant and the picture quality was really good. I asked him about light and that it would wash out the picture. He turned up the lights in the room and the image quality, from what I could tell, didnt change much at all.
How does the 8350 compare to the BenQ 1070? I know the epson is more in price, but as far as brightness and picture quality, how do they compare?
Also, the screen he was projecting it on was a Stewart screen. Said the screen was about $1500. In order to make a projector look good, do you really need to spend that much on a screen? Will the ~$200 screens give you a good image?
SDB553 is offline
post #16 of 34 Old 04-14-2014, 06:58 PM
Rarshaiz's Avatar
As I said before I would try the projector with out a screen first then if you decide the picture isn't quite what you would like then go after a screen. I have always projected on to a wall on flat grey paint but have seen them projected on white walls in both glossy and textured walls. The picture was always good. The only reason I have a screen now is the wall I want to project to has 3 windows on it. So I purchased a $500 screen 135" DaLite to cover the 3 windows and leave about 4 inches on both sides of the screen of wall left showing. If it was not for the windows I never would have bought a screen.
As for the BenQ Epson debate you are going to have to look at them separately or find a place that has a good return policy where you can buy and if you do not like it you can return it. All I can say is I have the BenQ w1070 I love it and for the price difference of the two I can buy 3-4 bulbs to replace in my W1070 or even wait a couple years and keep saving my money so that when the 4k projectors start filtering down to the budget range I have a big head start.
Think of projectors like stereo receivers and computers. They are always getting better and cheaper. If you bought today's top of the line model it will be outdated in 6 months by something better.
Rarshaiz is offline
post #17 of 34 Old 04-15-2014, 02:00 AM
Ftoast's Avatar
Liked: 549
In brightness and picture quality the 8350 and 1070 are pretty matched. The 1070 has a touch better contrast and the 8350 can squeeze out a few extra lumens, but the difference is small enough for most to call equal. The 1070 games better (low lag), has fantastic 3D, and is much cheaper. The 8350 has more flexible zoom/offset options if you need to mount your projector somewhere specific (to avoid a ceiling fan or beam). If you don't need the added placement options and aren't super RBE sensitive, I'd strongly suggest the Benq.
The only advantage that screen has is the ability to still look decent in a room with some angled lights hitting it. In a darker room a plain, cheap white screen will look fantastic and even have better viewing angles than that $1500 Stewart.
Ftoast is offline
post #18 of 34 Old 04-15-2014, 04:11 AM
wormraper's Avatar
Quoted: 311 Post(s)
Liked: 152
+1... a $500 or cheaper screen is MORE than enough. take a loot at the Elite screens.
post #19 of 34 Old 04-15-2014, 09:56 PM
AV_Integrated's Avatar
Quoted: 875 Post(s)
Liked: 659
...the screen was about $1500. In order to make a projector look good, do you really need to spend that much on a screen? Will the ~$200 screens give you a good image?
You need a good screen for best results. Don't confuse 'good' with 'expensive'.
If at all possible ALWAYS use a fixed frame screen.
If you must use a retractable screen, then use a tab-tensioned screen. Those are pricey, but actually worth the money.
Non-tab-tensioned screens are a waste of money, but often a necessary evil due to budgetary constraints. Spend as little as possible as the screen WILL develop waves in it and will be garbage bin quality in about 1-2 years or so.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #20 of 34 Old 04-15-2014, 10:42 PM
No way, the picture quality of the 1070 is WAY better than the 8350.
post #21 of 34 Old 04-16-2014, 09:10 PM
Ftoast's Avatar
Liked: 549
What's the measured contrast of the 8350? I thought it's just under 2000:1, but if it's notably lower I'd have to agree. Naturally the motion and ANSI numbers favor the 1070, but the native on/off (not dynamic) makes the biggest difference between two solid PJs with good color output.
Ftoast is offline
post #22 of 34 Old 04-17-2014, 12:20 PM
Quoted: 875 Post(s)
Liked: 659
I'm not sure the W1070 is 'way' better than the 8350. Certainly motion handling of DLP is a good deal better than LCD models, but the 8350 remains a very strong offering for projectors and has been a strong model for years. It has excellent black levels which were comparable to the flagship AE4000 from a few years ago when it was released. In general, minimal improvements have been made between the AE4000 and the AE8000 over the years, but there is a real jump in quality between the W1070 and the AE8000. To think the 8350 somehow is far worse than the W1070 just seems unrealistic. Good color, good black levels, decent motion handling. The 8350 is no slouch. But, given a choice, the added features of the W1070 certainly make it a winner in overall quality, but not really by as much as some people may feel.
post #23 of 34 Old 04-18-2014, 10:37 AM - Thread Starter
SDB553's Avatar
I think ive narrowed it down, tell me if this would work.
I'm looking to get the W1070 and the Elite Screen Electric100H.
There is a dealer in houston (housenkid.com) that apparently sells items he gets from cancelled online orders (not sure how this works but..), anyway, he has elite screens and has the 100H for $114, says it's new and in box.
I'm going to mount the projector on the wall behind my love seat. Cant really mount to ceiling due to fan in the way. The wall is about 11' 3" from where the screen would hang, so i'm assuming that throw distance would be somewhere around 10' 3"..or in that area.
According to projectorcentral, with a 100" diagonal screen, and a throw distance of 10' 3", id have a fl of about 31, which, from what im getting, is too high. Is there a way to adjust the brightness down on the 1070 to make this come more in line with the optimal numbers? It also says my seating distance should be between 10' 2" and 16'. My seating position would be roughly 8-9 feet.
with these numbers, would it be possible to use this setup?
SDB553 is offline
post #24 of 34 Old 04-18-2014, 12:34 PM
Quoted: 875 Post(s)
Liked: 659
The screen is weak, but a value for the price.
http://www.amazon.com/Elite-Screens-100-Inch-Projector/dp/B000YTRFEG/ref=sr_1_1?ie=UTF8&qid=1397849508&sr=8-1&keywords=elite+100+screen
Looking at the second photo on Amazon's website, it will be a very wavy screen, very quickly. That's typical of non-tensioned screens.
Don't worry about light output, you can dial it down in eco mode, or even get filters to bring light output down if needed.
Your seating distance shouldn't be an issue at all.
post #25 of 34 Old 04-18-2014, 12:57 PM - Thread Starter
SDB553's Avatar
would there be a better screen for the $100-$300 price range?
SDB553 is offline
post #26 of 34 Old 04-18-2014, 01:54 PM
Quoted: 875 Post(s)
Liked: 659
Not that I'm aware of. That doesn't mean that there aren't others, but retractable screens all develop waves in the material unless they are tab-tensioned (upwards from $1,000). I would probably get the screen you are looking at, then start saving to replace it in a couple of years with a tab-tensioned model.
post #27 of 34 Old 04-18-2014, 07:55 PM - Thread Starter
SDB553's Avatar
i know this may not be a "great" solution but...what if one were to tie the bottom of the screen to something so that when it is extended, it would be anchored at the bottom so to speak. This way, the screen stays straight and taught and maybe the wave issue wouldnt be as prevelant?
SDB553 is offline
post #28 of 34 Old 04-19-2014, 05:06 AM
rekbones's Avatar
Quoted: 308 Post(s)
Liked: 152
Sure this works to some extent but you may need to do this in more then just the corners and it kind defeats the retractable screen purpose, you might as well get a fixed frame to begin with.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Denon 1912 AVR, 7.1 with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #29 of 34 Old 04-19-2014, 07:45 AM - Thread Starter
SDB553's Avatar
sounds like a plan, I like the idea of a fixed screen, problem is, where to place it. my apartment really only has one area in which to watch TV/Movies, and thats the area where my current TV is. So mounting a fixed screen on the wall wouldnt work. I wonder if they make some sort of easle, or possibly a way to hang some chains from the ceiling, and when I want to watch the projector, I just put the fixed screen in place, and when I want to watch the LED tv, i can take it down. Granted, im not sure what the weight of a fixed screen is. I understand that screen material is fairly lightweight. I wonder if there is an option for this.
SDB553 is offline
post #30 of 34 Old 04-19-2014, 08:03 AM
rekbones's Avatar
Quoted: 308 Post(s)
Liked: 152
My 110" Jamestown screen hangs like a picture frame on a single French cleat and I can take it down and move it to my hallway by myself but wouldn't advise doing it on a regular basis. The Elite is all aluminum and might be lighter. I have seen some people have put it on a hinge and swing it up against the ceiling when not in use
rekbones is offline
