Improving Cable PQ on Projector (W1080ST) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-16-2014, 02:30 PM - Thread Starter
RigorousXChris's Avatar
Quoted: 140 Post(s)
Liked: 40
Hello everyone,
I'm using a BenQ 1080ST on a 120'' screen (Draper Luma 2). Previously I had a 65'' Plasma (Panasonic 65ST30).
Now when I watch HD sports channels, the picture is lacks sharpness and seems to have macroblocking and/or pixelated (not sure of proper term here) versus my Plasma. The plasma beats it by a long shot.
I understand this may seem impossible since my screen is nearly three times the volume. Is there a way to improve my BenQ picture to get closer to the plasma?
I've already calibrated it (Disney WOW & DVE HD), but I wanted to make sure I wasn't missing anything. If it's just compression from the cable company, then I guess that's all I can do.
Is there any A/V equipment that can improve HD Cable PQ? Mostly I care about Sports, I'm usually the go to guy for sporting events. Would outputting the cable through a PC be an alternative? Or upscaling from a receiver?
JVC RS500 | Sony HW40ES | Pioneer SC-95 | Panamax MB1500
Klipsch RP-280FA | RP-450CA | RP-260F | RP-250S | RP-140SA | R-115SW x2
4k MadVR HTPC | Panasonic DMP-UB900 | PS4 Pro | DirecTV Genie
RigorousXChris is offline
post #2 of 4 Old 04-16-2014, 08:09 PM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
Are you running the projector directly via HDMI from the cable box, or is it passing through an A/V receiver first? If running through an A/V receiver, bypass it and run it directly to see if that impacts the image at all.
If your cable box has component video output, you may want to give that a try as well.
I know my Denon tends to induce some noise from time to time using its internal scaling, and it's not a good thing. I get great results using component or a direct feed via HDMI.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 04-17-2014, 11:45 AM
Natrix1973's Avatar
Quoted: 51 Post(s)
Liked: 40
I just got a 1080st and my 130" home made screen set up this week so I was going to start a thread about this myself.
I helped my picture quality by using the scaler in my Yamaha A3020 receiver to upscale my Directv output to 1080P. That took care of a lot of the macroblocking. The picture still looks a little dull and fuzzy especially compared to a Blu Ray but that is to be expected. I am going to have to monkey with the picture settings to see if I can help get the picture to pop a little bit more.
Natrix1973 is offline
post #4 of 4 Old 04-17-2014, 11:56 AM - Thread Starter
Quoted: 140 Post(s)
Liked: 40
Interesting. Yep I'm passing it through my A/V receiver right now. I'll see if it running it directly to the cable box improves it.
