Suggesstion for this application - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-17-2014, 03:29 PM - Thread Starter
Jimbo2012's Avatar
I was going to buy a Benq 1070, but I see a problem with the focal length.
I was all set to buy one but I was told the distance to the screen being 192" from the lens is not going to work on my 130" diag screen wall.
Any opinions?
Or if you agree what other models might work with similar price quality?
Jimbo2012 is offline
post #2 of 4 Old 04-17-2014, 07:20 PM
AV_Integrated's Avatar
Quoted: 1125 Post(s)
Liked: 819
Any opinions?
If you have no choice but to put the projector where it is 16' from LENS TO SCREEN, then these are your options:
http://www.projectorcentral.com/projectors.cfm?g=1&hide=0&st=1&mfg=&p=300&p=1500&w=&r=13&br=&ll=&ltg=&t=&db=&dt=&c=&ar=&dvi=&wr=&pjl=&pjw=&pjh=&td=16&i=d&is=130&sort=pop&sz=15
The Optoma HD25 and HD131 models are closest in quality to the BenQ.
The W1070 hits a 130" diagonal from 10'11" to 14'2" from lens to screen.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 04-18-2014, 03:19 AM - Thread Starter
Jimbo2012's Avatar
The Optoma hd25 is interesting as well as the hd 25e and the hd 25LV
Need to see the differences between all those
The Benq w1500 I guess needs to be compared any opinions with these?
post #4 of 4 Old 04-18-2014, 02:05 PM
Ftoast's Avatar
Quoted: 2199 Post(s)
Liked: 697
The original hd25 (if you can find one) uses an RGBRGB colorwheel and a brighter lamp while the 25e and 25lv use RGBCYM wheels to increase white-brightness and lower color-brightness. The increased white (using a lower watt lamp) means that proper calibration also lowers the contrast quite a bit on the 25e/25lv. The higher watt lamps cost more to replace, but otherwise the hd25 is the one to get..out of those three.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
