Epson PowerLite 905 problems - AVS Forum
post #1 of 3 Old 06-09-2014, 11:23 AM - Thread Starter
foxlavolpe's Avatar
Hi, just need to know how to fix this problem. replaced the bulb and this is the pictureProcessed By eBay with ImageMagick, z1.1.0. ||B2
is there any reset or setting  or wrong installation of the bulb or what?
foxlavolpe is offline
post #2 of 3 Old 06-09-2014, 11:47 AM
AV_Integrated's Avatar
Quoted: 129 Post(s)
Liked: 270
Did you use a Epson original lamp branded by Epson?
While it looks like a LCD panel alignment issue, it would be very unusual for this issue to be related to the lamp. Darn near impossible actually.
If this issue appeared before the lamp change, or if you've never seen this projector work (bought it used), then this needs to go into Epson for repair. This is not a simple fix to get LCD panels into alignment.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 3 Old 06-09-2014, 12:27 PM - Thread Starter
foxlavolpe's Avatar
yes the lamp is original Epson...  I do not know if the problem was already there since the lamp was at the end..
I see some projectors from epson have the alignment setting.. but this one not...
doing a research look like the alignment problem shows as a different problem...
can be anything else?  like lens or just some setting?
User Tag List
