Epson TW3500 on a monoprice ceiling bracket - AVS Forum
post #1 of 4 Old 06-10-2014, 10:22 AM - Thread Starter
BVG
BVG's Avatar
Hi everyone,
I'm have a monoprice ceiling bracket like this one:
and I want to fit it on a Epson TW3500.
I did it, but the problem is the gravity center of this projector, which is a little more close to the front, and not the really center of the projector.
I think it's not possible to do with this ceiling bracket.
Anyone with the same problem? Solutions?
This bracket is already above of the suspended ceiling, so I must use this mounting.
Regards.
BVG is offline
post #2 of 4 Old 06-10-2014, 10:48 AM - Thread Starter
BVG
BVG's Avatar
It seems that I'm not the only one:
http://www.avsforum.com/t/1294329/advice-on-choosing-a-ceiling-mount-for-epson-8350
BVG is offline
post #3 of 4 Old 06-10-2014, 07:44 PM
AV_Integrated's Avatar
Quoted: 118 Post(s)
Liked: 265
While I've spoken at length about this, the reality remains that almost all projector ceiling mounts are complete junk. There are a few decent mounts that do a fair job, but you really should be looking at a used Chief RPMAU, the Peerless PRGU or the older and cheaper Chief RPAU mounts.
They cost a fair bit more, but actually will hold a projector without issue.
http://www.ebay.com/itm/CHIEF-RPMAU-/261500162075?pt=US_Projector_Mounts_Stands&hash=item3ce29fd01b
$100 and you will never need a projector mount again, and you will understand why as soon as you put it on.
With an electric drill you could modify this mount and make it work with some brackets from the local hardware store for even less...
http://www.ebay.com/itm/CHIEF-RPA-ELITE-PROJECTOR-MOUNT-MODEL-RPM985-/291163010698?pt=US_Projector_Parts_Accessories&hash=item43caaaf68a
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #4 of 4 Old 06-10-2014, 11:38 PM - Thread Starter
BVG
BVG's Avatar
AV_Integrated, thanks for your reply, but I will try something like this:
http://lowtek.ca/roo/2008/diy-ceiling-mount/comment-page-1/.
I just need to find the gravity center of My TW3500 (why Epson doesn't locate the gravity center on the bottom?).
BVG is offline
User Tag List
