low ceiling flush installing? - AVS Forum | Home Theater Discussions And Reviews
Old 06-16-2014, 11:22 PM - Thread Starter
cyhe1314's Avatar
I've bought the BenQ W1080ST. My very first, and loving it! The problem is that I hate how I have to have it dangle down from the ceiling.
Are there mounts where I can have it mounted flushed against the ceiling?
One option that came to mind is to mount it on a metal plate slightly wider than the projector, and screw the plate tight against the ceiling.
Do I have any other "professional" options?
cyhe1314 is offline
Old 06-17-2014, 06:58 AM
Adult Beverage's Avatar
Quoted: 39 Post(s)
Liked: 27
To help prevent overheating the manufacturers recommend a minimum distance from the ceiling. Chief makes some very low profile mounts that would get it to within about 3 inches of the ceiling.
http://www.chiefmfg.com/Products/RSAU
Think ya used enough dynamite there, Butch?
Adult Beverage is offline
Old 06-17-2014, 09:41 AM
AV_Integrated's Avatar
Quoted: 988 Post(s)
Liked: 728
Yeah, it totally depends on the mount you are purchasing. The Chief RPA series are some of the lowest profile mounts out there. If you go for a custom plate (or modify a used plate) you can get an even lower profile than the universal plates.
Now, what you are describing sounds like it makes sense, but it doesn't.
You MUST be able to adjust tilt/yaw/rotation for the projector. If your ceiling isn't level to the screen, then you can't adjust it with what you are describing. You also can't rotate the projector, or tilt it if it's not square to the screen.
Realistically, the concept is really nice and something I've been bouncing around with for a few days. I may put together some sort of design for a flush ceiling mount that gets the projector within an inch of the ceiling in some manner and maintains adjustments, and universal fit. Not sure if I can keep quick release in the mix... but maybe. It's certainly a request that I've heard more than once and would be a nice product to add to the mix.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
ceiling , flush , mount
