When is someone going to make a decent projector? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 80 Old 06-29-2014, 04:21 PM
Quoted: 24 Post(s)
Originally Posted by Bsims2719 View Post
No not latest and greatest!! Just decent
Your definition of decent is, in fact, quite demanding.
Easy!!
What makes you think this?
A couple of engineers at Benq could build this for the same component cost as the Benq W1070st.
The only thing that they would have to recoup is R&D.
You seem to be under the impression that you can, right now, get a 2000 lumen LED light source with color and greyscale accuracy equal to bulb+wheel for cheap, and I'm not sure where you're getting this idea.
This whole thread is pretty much halfway between Homer's Dream Car and "why don't they make the whole plane out of the black box material?"
sethsez is offline
post #32 of 80 Old 06-29-2014, 04:48 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Yes, our schools have failed.
Nicktx27 is offline
post #33 of 80 Old 06-29-2014, 09:25 PM
Ftoast's Avatar
Quoted: 1895 Post(s)
Liked: 617
The efficiency of watts/heat per lumen on hpmv lamps is very high, so high that you will still require the same amount of fanspeed (or more) to protect a 1000-2000lumen outputting (to screen) LED/laser source.
There are only two lampless options in current production: LED (or hybrid which is limited by the LEDs) which max out around 450 color correct lumens, and laser on phosphor which is large, hot and very expensive..and doesn't have the lifespan of LED.
For the record, the small-cased (but not pico) LG 75/80/85 runs VERY quietly in all but the very brightest mode.
I can agree that a slightly bigger case than pico's can make a big difference in noise.
Dimming LEDs cause strong colorshifts and nobody seems to have done well to counteract this. Any dimming beyond 3-5X (far from infinity) can be visually distracting.
You'd be hardpressed to notice the effects of the cheap optics in a cheap projector with most moving video..just like you won't notice the full resolution of your 1080 phone until you can focus your eyes 4-5inches from the screen. ..or notice that it's using a pentile matrix.
If you don't need shortthrow because there are standard options that are nearly silent even from a couple feet away from your head, and you're okay closing some curtains, what you've asked for is largely available right now for an affordable price.
Ftoast is offline
post #34 of 80 Old 06-30-2014, 09:56 AM
AV_Integrated's Avatar
Quoted: 957 Post(s)
Liked: 709
The one part of all of this that I agree with wholeheartedly is that with recent advancements to deliver reasonably solid light output from LED projectors, still has only netted one 1080p model that's affordable and decent in the LG PF85U.
It certainly seems overdue for a W1070/W1080ST type model with LED. Potentially quieter fans due to lower heat on the light engine, and a 'forever' light source. The contrast is a different issue, as infinite dimming does nothing in an ANSI test pattern, or with real world design. There is no such thing as infinite contrast that actually produces a solid image that I have heard of. There are always compromises.
Still, things are certainly moving that direction, and in this niche market of front projection, it's 4K that's likely to have the upper hand for the next few years.
I have said for a couple of years that if they can build a 720p LED projector for $500 and a great looking 1080p projector for about $1,000, then why the heck can't we get that great looking 1080p projector, with an LED engine in it?
But, just because I want to see it, doesn't mean I get the complexities of why I haven't seen it, and more to the point, I am certainly not 'demanding' to see it. I just look forward to a point where we can see a true 1,200+ lumen from a LED light source on a 1080p/3D chip set, or maybe even UHD at that point.
LED seems like a race to the bottom instead of a race to the middle. So, there is some disconnect there.
The request for ultra short throw is naive as it flies in the face of optical design. Short throw (such as the W1080ST), is more achievable, but adds cost. Consider that the W1070 and the W1080ST are almost identical projectors, but have a cost difference of several hundred dollars. That's what a decent short throw lens adds to the mix.
Flip side is that many want a projector out of the line of sight. I have a deep admiration for the lens on the Epson 8350, or their 5030. Mid to long throw, a ton of lens shift... Take the Sony 40ES which is extremely quiet and produces a great image. Take the LCoS chip set from the JVC projectors (1080p) or the Sony 4K chip (100ES).
Laser? I'm not sure which manufacturer is doing anything with lasers for any reasonable price right now, so we'll throw that in the 'fiction' category for the moment.
Two step forwards, one step back? I'm not sure about that. I just think that when you look at commodity pricing and putting out a decent product (of which there are many) to consumers, you have to have a target which reaches the most people. A typical room may be 10-14 feet deep, ceilings may be 7'-8' tall in a basement area, or due to soffits. The use of short throw optics adds a great deal to the cost, the use of a LED engine takes away a lot of lumens. The use of a 5 segment color wheel adds brightness statistics, but harms overall image quality. The use of a 2x color wheel with a clear segment does as well. The BenQ W1070 is one of the most well thought out projectors on the market. Variants within a couple hundred dollars or so which swapped the lens for one with better zoom and lens shift would be nice. They already have the short throw version. A LED based version would certainly be nice for those who don't need the light output of the current model.
I think one of the biggest two forward, one back violators was Epson when they got rid of their excellent zoom/shift lens they used on the 8350, when the 3020 came along. I'm strongly of the belief that they stopped using that lens because it drove sales away from their 8700UB model to the 8350 and they didn't want that to happen with the 5020 and the 3020. So, around $1,000 you have the 8345 and AR100 with good zoom and lens shift, but from there you have to go to the Panasonic AE8000 or Sony 40ES (not as good) or the Epson 5030 to really get that versatility. I think that's a real shame and I would love to see that type of lens in Optoma, InFocus, and BenQ projectors as well as the cheaper Epson models again.
Give it time, and we will see all of this come down the road. I have no issues waiting patiently, even if some others do.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #35 of 80 Old 06-30-2014, 11:10 AM
airscapes's Avatar
Quoted: 347 Post(s)
Liked: 283
I'm frustrated with the projector market. IMO there is nothing really good out there. It's either low res, to loud, to expensive, expensive lamps, poor contrast, etc.
What is frustrating is that all of the individual technologies to make a really good projector have been available for some time but for some reason manufacturers are stuck in this creep mode. Not only that but these solid state components are relatively cheap when mass produced.
Here is what I need. Ultra short throw, good optics, scanning laser with infinite contrast, 1080p and at least 2000 lumens capable of 150 inch image.
I would be willing to bet that the manufacturing cost would be less than $2000. I am willing to pay $3000.
When is someone going to mass produce something really good?
When it is profitable!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #36 of 80 Old 06-30-2014, 11:40 AM
Quoted: 119 Post(s)
Liked: 158
While we're listing things we can't have, I'd like a pony.
PJC Bill is offline
post #37 of 80 Old 06-30-2014, 09:42 PM
fierce_gt's Avatar
Quoted: 1621 Post(s)
Liked: 1560
Actually scanning lasers have infinite contrast.
with projection, it's about the room. a projector that displays 0.0000fl black levels can still end up with terrible contrast in a 'normal' room. it gets even worse if the white levels are super bright.
so, even if that's the case. with actual content on screen, the brighter the image, the worse the black levels. the only way to avoid that is with room treatment. nothing can be done on the projector to fix the fact that it's difficult to make a white screen look black.
fierce_gt is offline
post #38 of 80 Old 06-30-2014, 09:55 PM
fierce_gt's Avatar
Liked: 1560
Again missing the point. The global market isn't set up to buy individual components for projectors. Now you are really talking niche market. A market where people who want to assemble their own projectors.
How much do you think a laptop would cost if you bought all the individual pieces that make it up assuming that you could find them?
The point is that electronics mass produced are crazy cheap. My cell phone has 1080p resolution, infinite contrast, and more computing power than a desktop bought a few years back, a better camera than the one I bought a few years back, an led light source and is manufactured for a cost of around 150 dollars.
The point is that all the pieces off the puzzle of making a relatively inexpensive high quality projector are there. When is someone going build it?
but now you're assuming that everybody wants the same thing...
either, there are several options to satisfy all the needs of the market, but we pay slightly more because of lower production. or, we all have to buy the same thing, and maybe they'll pass the savings on to the consumer.
what it sounds like to me, is you want something that looks really good on paper with awesome specs for a low price. but many of us want something that's made to a higher quality. your cell phone camera may be 1080p capable, and have 18MP's or whatever, but there's still a very good reason 99.9% of all professional photographers don't use their cell phones.
anyway, I simply disagree that that pieces have yet to be assembled. they have been. if you want a projector with 'ok' performance and an LED light source. it's out there, it's just not going to cost as little as the w1070 because it costs more to build. If you want an LED projector for the same price as the w1070, it's also out there, but it won't be as good. there are also LED projectors on the market with better performance than the w1070, and ones that are cheaper too. they've been made, they just don't cost what you think they should, maybe because they aren't sold in high enough numbers. but they aren't sold in high enough numbers because there's actually not that many ppl that want them.
post #39 of 80 Old 06-30-2014, 10:01 PM
fierce_gt's Avatar
Liked: 1560
Originally Posted by Nicktx27 View Post
I think you are very ignorant of the tech and it's ability.
well he did compare it to cold fusion...
a little bit of knowledge is a dangerous thing.
post #40 of 80 Old 07-01-2014, 06:25 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Lol! Good point.
Nicktx27 is offline
post #41 of 80 Old 07-01-2014, 06:28 PM
kevinlg's Avatar
Quoted: 267 Post(s)
Liked: 130
So let's see what you want
Ultra short throw? It seems you want this due to fan noise, the Sony hw40es is literally 4 feet on top of my head and the thing is whisper quiet at 21db, so that issue is fixed
good optics? It has full 3d 1080p with LCoS technology with delivers an amazing image.
scanning laser with infinite contrast? no idea what that is, looked it up and looks stupid and outdated tech
1080p? yes and full 3d
at least 2000 lumens capable of 150 inch image? it's not 2000 lumens but game mode is 1714 lumens, this puppy will torch a 150 inch image so that won't be a worry either.
It even zooms and has lens shift.
You said you would pay "$3000" for such unit well when you're ready I'll sell ya mine for $3000
Only con is the "lamp replacement" but put it in low mode and youll be able to watch about 4~ hours a day for two years just fine.
ben38 and Ftoast like this.
kevinlg is offline
post #42 of 80 Old 07-01-2014, 07:44 PM
Ftoast's Avatar
Liked: 617
And its $1000 savings will allow another 8years on top of that; so ten years of top-notch, silent, flexible operation..that also happens to game well with really low input lag. Sounds like you've got a winner within budget.
Ftoast is offline
post #43 of 80 Old 07-01-2014, 09:23 PM
Quoted: 957 Post(s)
Liked: 709
Junk, junk, junk! Nothing but junk I tell ya!
You are missing the point!
When is someone going to come out with a DECENT projector?
I think he missed the CRE thread.
ben38 and pajama sam like this.
post #44 of 80 Old 07-02-2014, 12:19 AM
Ftoast's Avatar
Liked: 617
I suppose it's really the same point you and others have mentioned in part though..besides the silly comparison to 5" single-panel amoled (a $75-110 part all by itself, accounting for over half the devices construction cost).
Forgetting for a moment that current gen LED is bright enough for most projection rooms already, it is dumb that no company has basically tossed the innards of a pf80/85 into a 8350/8345 case and called it "good".
The parts (if possible to work together a hardy zoom/offset range with dlp) have already been sold as inexpensive units and proven both successful AND ..inexpensive. It would seem an easy choice for any company like Aaxa or infocus who doesn't even HAVE a top-end theater model. It isn't like it would steal the thunder from a higher model if one doesn't exist! Aaxa's "top model" currently is a $500 720p unit that lacks 3D..I'm pretty sure they could squeeze something like this in. Infocus doesn't even have an RGBRGB model right now, they could use a bit of theater to round out the line.
On a related note, I'll also take a pony. Screw gas, hay is cheaper. I don't have $3000 and need to start saving, somehow.
Ftoast is offline
post #45 of 80 Old 07-02-2014, 11:29 AM
Quoted: 119 Post(s)
Liked: 158
Originally Posted by Ftoast View Post
Forgetting for a moment that current gen LED is bright enough for most projection rooms already...
It's not, though. It's bright enough for some people, some of the time, if they have excellent light control.
...it is dumb that no company has basically tossed the innards of a pf80/85 into a 8350/8345 case and called it "good"...
Like all other corporations, projector manufacturers love money. LOVE money. If it were this easy, it would already be done.
The parts (if possible to work together a hardy zoom/offset range with dlp)...
Have you ever noticed how LCD projectors tend to have more zoom/shift than DLP projectors? It's easier to do lens shift with LCD projectors. Please note that I'm not an engineer, but I've heard this over and over again from engineers, so I'm trusting it.
More generally:
The fact that there is not an inexpensive, high-quality, solid-state (lamp free) home theater projector means one of two things. Either:
1. Building one is harder than it looks
Or:
2. It's easy. However, there is a vast, industry-wide conspiracy to maintain the current lamp-based status quo at all costs, no matter what, in order to keep selling replacement lamps forever and ever and deprive poor suckers like you and me of our Eternity Projectors with Infinite Contrast. And despite the intense competition between projector vendors, not to mention the years-old fight between 3LCD and TI/DLP, not a single person has blabbed a single word in all these years.
I mean, believe the second one if you want to, I guess.
PJC Bill is offline
post #46 of 80 Old 07-02-2014, 12:32 PM
Hank's Avatar
Quoted: 67 Post(s)
Liked: 26
My company recently got out of the projector biz. We invented short throw projection (called it Super Close Projection). We came out with the first mass marketed pocket projectors - had a brilliant unit powered with a ROKU stick. Every time I showed someone one of our pocket projectors, they asked where they could buy one. Market awareness was the problem and there isn't enough millions available to spend on advertising to make a large enough market "aware" of the product, so quality pocket projectors remained too low volume to make money. Large business projectors became a commodity, and sufferred margin erosion. Our material is in nearly every LCD TV and we now have QBEF film that will make an LCD look like OLED (ASUS just adopted this for their upcoming high end laptop). Our material is in high volume smart phones.
Why do I state all this - to brag? No, to tell the OP that I know what costs are in projection and smart phones. Your smart phone didn't cost $150 to make - it is being heavily subsidized by your cell carrier. Short throw projection requires a relatively huge aspherical lens, which is extremely difficult to manufacture - only a few lens manufactures can actually make them and they have to normally go through 3 or 4 tooling iterations to get them correct. I know the LED biz too - our pico (pocket) light engines used the latest and greatest LED's. One thing I didn't notice in this thread is that you must keep in mind that in the world of electronics, projectors as a whole are a small volume niche market. Comparing component costs with those of smart phones and notebook computers is very apples/oranges. I believe the major projector brands are working in their labs to design LED-based 1080p, high contrast, high color uniformity products and they probably have paper designs they could start manufacturing within months, but at a MSRP that their Marketers are tellling them is too high for any decent volume. The other major item is that the entire projector market is satisfied with affordable lamp-based projectors. Only a fraction of a percent of buyers, such as a few on this forum, are clamoring for LED. Them's the non-emotional facts, boys.
I don't want a pony, but a cheetah would be a cool pet.
shingles314 and reckless7 like this.
Hank is offline
post #47 of 80 Old 07-02-2014, 01:04 PM
Ftoast's Avatar
Liked: 617
More generally:
Or:
I have yet to find a casual viewer complain of it being too dim with the use of a curtain or two (doesn't mean much, but it's not nothing). 110"-120" is a pretty common indoor size and curtains are cheap and rarely ruled-out by significant others. To each there own, but judging by the popularity of the easy/inexpensive lcdTV I'd have to guess there's a large market for cheap, easy, and "good enough".
More than the love of money I'd argue they simply make some very odd choices and are a little clumsy with change.
I've specifically named a couple companies that have nothing to lose from adding a slightly higher-performance hometheater oriented projector to their line.
I've seen a couple DLP models with fairly extreme zoom, but never much offset range..and that's why I questioned if it could be done at all. You WOULD think a system of offset/zoom lenses at the end of the line couldn't possibly care what technology preceded it..and that'd be a possible design to try.
If a DLP only company wanted to offer a more competitive model to gain more profit at the competition's expense, that'd be something to try..but, like I said, it would involve a bit of change and companies make some odd choices.
I feel like I'm being told that the w1070 with its combination of zoom/offset/accuracy/and $750-1000 couldn't possibly be done until now. Why not, just because that simple, obvious, and award winning combination wasn't thrown together just yet? The hd25 and any previous inexpensive iris-less RGB DLP could've been tossed into a more placement friendly chassis as soon as 1080 parts came down in price. It wouldn't have been stealing any more from their business line or iris'd high-end then than it is right now for Benq.
Some people say the w1070 is too bright and loud, but Optoma has never popped a different software set and RGBRGB colorwheel into a 131xe with its 190w lamp for a build-price difference and R&D cost of $0 ..does that mean it can't be done?
I'd say it's much more likely it's the natural slow response and odd choices of a large company.
A colorwheel swap and the resulting software difference doesn't even require a true separate overhead for a different model..it's parts they already have and software they already own and use.
Conspiracy, no. Slow, ignorant and generally silly, oh-my yes.
I'm not asking for the best glass in a $500 package. I'm wondering why there aren't slightly larger/quieter, 300-600lumen LED DLPs with similar zoom/offset options as the w1070 for $800-1200...at least by a company with no current theater model for it to leak sales from.
You can't seriously believe that it can't be done, can't be done inexpensively at a normal profit margin, or can't be done by a company with no theater models without stealing too many sales from their lights-on business segment.
Not that I'm siding completely with OP, but. ..I'm admittedly impatient. This isn't even FOR ME! I couldn't care less about ceiling-mount flexibility, I just want to see an LED option that makes more sense in a high mount.
I've also heard from manufacturers that they really don't like to change their case designs..so anything that doesn't fit or simply drop in, that's going to take a while. It's understandable..but tell me straight that you aren't disappointed in hearing it.
Ftoast is offline
post #48 of 80 Old 07-03-2014, 10:20 AM
Haw
Haw's Avatar
Quoted: 18 Post(s)
Sony has actually developed a 4K Ultra Short Throw Laser projector and launching summer this year.
www.redsharknews.com/technology/item/1410-sony-develop-an-ultra-short-throw-4k-laser-projector
www.sony.net/Products/4k-ultra-short-throw/
Haw is offline
post #49 of 80 Old 07-03-2014, 12:17 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Not at the impossible price point the OP wants.
Nicktx27 is offline
post #50 of 80 Old 07-03-2014, 01:22 PM
fierce_gt's Avatar
Liked: 1560
what's ironic is that such a design would actually be a lot more intrusive and difficult to place than the conventional projectors for me.
I've rather have the projector hidden behind me than occupying the entire front of my room. it is cool for the right application though!
post #51 of 80 Old 07-03-2014, 09:38 PM - Thread Starter
Bsims2719's Avatar
Quoted: 26 Post(s)
Now see that's what I'm talking about. Someone is trying to make a decent projector.
Now all they have to do is;
1. Swap the laser light source to led to keep cost down until laser is slightly more mature.
2. Use a 1080p chip to keep component cost down.
3. Decrease the size of the chassis and weight to make it more manageable for ceiling mount.
4. Add wifi and wireless HDMI to reduce wiring.
5. Add an easy mounting plate so that the mounting is not intimidating for the typical buyer.
6. Mass produce it to reduce component cost.
No bulb, no fan noise, small footprint, good wife factor.
We need a paradigm shift in projector manufacturing. Small, cheap, no maintenance and good just like all the other electronic industries. Cell phones, laptops, etc.....
Bsims2719 is offline
post #52 of 80 Old 07-03-2014, 09:52 PM - Thread Starter
Bsims2719's Avatar
Quoted: 26 Post(s)
It will lose half it's brightness after about 500 hours not to mention color shift not to mention it will never have the color depth of a good led. No matter how good the projector is a bulb is old technology.
What percentage of TV's sold today are leds? What percentage of laptops are led? What percentage of projectors are leds?
post #53 of 80 Old 07-03-2014, 10:09 PM - Thread Starter
Bsims2719's Avatar
Quoted: 26 Post(s)
More generally:
Or:
Please, please, please... I wish everyone on this thread would dispel the belief that just because the "industry" doesn't do it, it must be impossible or unattainable.
How long, how many decades, did GM, Ford and Chrysler make crap cars without any innovation before Toyota and Honda forced them to change.
I mean the iphone was introduced in 2007. Look at what cell phones are capable of today. If you told someone in 2005 what a cell phone can do today would they believe you?
All I'm saying is that the projector industry is crap. They need to innovate. They need a paradigm shift in value. A really big image for cheap.
The technology is there it's just that no one will take the lead. Again to my point, LG is the first one to step forward and truly innovate and they are not even a typical projector manufacturer. How stupid is that?
post #54 of 80 Old 07-04-2014, 01:37 AM
Quoted: 24 Post(s)
What you're ignoring is that this has been happening. Prices are dropping on everything... hell, you can get a 1080p projector for $650 now if you wanted. Even bulbs are dropping in price. LED is a relatively new technology in projectors (you can't compare their use in projectors to their use in other consumer products, the amount of light they need to consistently put out is much higher), and yet we've gone from 60 lumen 480p units to 1000 lumen 1080p units in only a few years. Lumen counts are rising, contrast ratios are improving, noise levels are dropping, and we've got more technology options now than ever before.
Could things be better? Sure they could. But we're clearly on our way there. To complain that we're not there yet is silly. It's not like all the progress made over the past few years is coming to a grinding halt any time soon.
And again, making things ultra-short-throw does not make a projector more user-friendly. It's absolutely brutal for showing imperfections in your wall or screen and can be much harder to get your ideal screen size from, and in that sense can be more limiting or difficult than a standard long-throw projector, which is why they're not terribly popular for home theaters in the first place. It's the kind of thing that sounds nice until you actually deal with it.
Which gets to the second point... a projector that's easier to ceiling mount is still going to be a niche product just by virtue of ceiling-mounting being a hell of a lot more difficult than putting a TV on a stand. People who rent or live in apartments sometimes aren't even allowed to put in ceiling mounts. As long as projectors are more work than TVs they will always be niche, and as long as they're niche there's a limit on how far you can mass-produce your way to savings.
fierce_gt and Ftoast like this.
sethsez is offline
post #55 of 80 Old 07-04-2014, 08:13 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
About as stupid as someone who thinks it's as easy as slapping some parts from a bin together. Seriously man, you need to take an Econ 101 course.
kevinlg likes this.
Nicktx27 is offline
post #56 of 80 Old 07-04-2014, 11:45 AM
fierce_gt's Avatar
Liked: 1560
I just find it funny because I think of all the CE divisions, projectors are near the top for the most change, innovation, and value increase in the last 5yrs.
I mean TV's have actually gotten worse, nothing has changed with speakers or amps, processors are only keeping up with new formats... the difference I've seen with projectors is that 3k 5yrs ago would get you an entry level 1080p that MIGHT match LCD tv contrast and picture quality. today 3k gets you a nice mid-range 1080p projector that matches the best plasma on the market for picture quality.
imo, that's a HUGE change. and the fact that more than 1% of the population is even considering a projector, now they there are led models, and short throw models, and GOOD looking ones for under 800bux, it's not even that 'special' to have a projector anymore. when I got my first, my friends thought I was nuts, and weird. now they all want one of their own. and hey, if we go back even further, it was only about 15yrs ago when I thought owning a front projector was a pipe dream because I didn't have the 20k to spend on a projector, or the 100k to spend on renovating the room so that I could actually use one. to have gone from that to a point where you can buy a 1080p projector small enough to be portable and just point it at a wall and go, is nothing short of amazing to me.
so when I hear all these ppl complaining about how stagnant the projector market is, and why they haven't made the perfect projector yet, I honestly can't even imagine what led to that complaint. my only explanation is they never looked at projectors until 5months ago, and they assume it's been this way forever(but it hasn't)
PJC Bill and sethsez like this.
post #57 of 80 Old 07-04-2014, 11:48 AM
fierce_gt's Avatar
Liked: 1560
you realize there's virtually no correlation between LED tv and LED projectors right?
post #58 of 80 Old 07-04-2014, 09:07 PM
kevinlg's Avatar
Quoted: 267 Post(s)
Liked: 130
No it will not, what is up with you and LED? You're so stuck on that tech that you're most likely one of those guys that love their tv/projector in torch mode.
LED projectors are crap, the bulb lasts long but the colors are awful and don't even get me started on blacks! Go buy a razor lit LED tv and be happy with your crap technology, while us projector owners enjoy our natural and great colours that are easy on the eyes.
kevinlg is offline
post #59 of 80 Old 07-04-2014, 09:14 PM
fierce_gt's Avatar
Liked: 1560
well, there are some advantages to LED projectors that use RGB led's. it's very different from the crappy edgelit LED TV's, and from what I've heard the LED projectors(the good ones) appear to have more saturated and accurate colors. at the very least, they are capable of matching rec709 standards. and they will maintain brightness and have virtually no color drift over time. again, there's really no correlation between LED TV's and LED projectors.
the blacks though, seem to be more limited by DLP technology, as I don't believe any LCOS models have used LED lighting yet. still, I'd take an LED DLP with dynamic dimming over a bulb based DLP with a dynamic iris. I just don't see the point is spending $1000's more for an LED model just to save a few hundred on bulbs. when the LED models are closer in price to their comparable bulb based competition, that's when LED will make a whole lot of sense. I'm hoping we're not too far off. there's been HUGE advancements in LED projectors in just the past 2yrs.
maybe we'll even be lucky enough to see an LED LCOS projector with the same great blacks and contrast we've come to expect from one.
post #60 of 80 Old 07-05-2014, 03:17 AM
Seegs108's Avatar
Quoted: 4172 Post(s)
Liked: 2053
The ONLY projector that comes remotely close to what the OP wants is the Runco LS-100D. I currently own one. 1080p DC4 DMD with ultra short throw optics that actually provide a sharp image. It has an LED light engine and in it's most aggressive DI mode offers truly infinite contrast as the LEDs will shut off completely for a black level reading. The only shortcoming is the brightness spec. With a few tweaks you can get brightness up to about 800 lumens. LEDs used in projectors just aren't bright enough to get to the lumen spec the OP wants. I currently have it for sale in the classifieds section of this forum if you're interested.
But with that said. I have a feeling you don't fully understand the projector market if you think a company can bring you the product you want at the price point you want. It doesn't work that way. Yes the LEDs are cheap, but that's besides the point. To get a decent performing DLP DMD in regards to contrast you have to pay through the roof for it. TI grades their DMDs and charges manufacturers a LOT more money for them as you go up in contrast performance. Then you need to factor in the optics needed for not only ultra short throw, but also the larger .95" DMD as these are the only ones that offer competitive contrast performance. So large size (a necessity if you want to use the larger DMD to get competitive contrast performance) and unique shaped lenses for ultra short throw that offer decent sharpness on the cheap? I don't think so. If you think you could get away with a BenQ 1070-type quality lens for ultra short throw you have absolutely no idea what you're talking about and should stop posting about the subject altogether. Then we need to factor in decent video processing. Video processing can make or break the overall PQ of a projector. Poor processing can result in a noisy image, poor motion handling, and a soft looking image among many other things. While the price has gone down in the 1080p world for adequate processing/scaling, just like higher grade DMDs, processing boards that offer better than average performance have a premium. Also factor in R&D (yes, unfortunately great performing intellectual properties like dynamic iris algorithms and color management systems cost a lot money to develop), half way decent manufacturing quality control, a solid warranty, and decent build quality and you wonder why a company can't bring us a product like the one you want for under $3000. Please take a moment and take a step back and think about how the world really works and then you'll understand why there isn't a product out there (other than the LS-100D) that meets most of the standards you're looking for in a projector.
One of the huge problems people have with quality projectors is the price. Unfortunately, unlike TVs, the price for these high PQ units will stay high because quality glass optics will ALWAYS be expensive. Projectors have always been and will probably always will be far too niche so that mass production will lower the price point for adequate lens quality the OP wants at the price point he wants. This alone is the reason you're never going to get what you want at the price you want. It's sad but true. Just like camera lenses you need to pay a LOT for quality glass. For what you want, you need high quality glass lenses.
Seegs108 is online now
