When is someone going to make a decent projector? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 07-05-2014, 06:42 AM
Ftoast's Avatar
Quoted: 1918 Post(s)
Liked: 624
Originally Posted by fierce_gt View Post
... I don't believe any LCOS models have used LED lighting yet.
... maybe we'll even be lucky enough to see an LED LCOS projector with the same great blacks and contrast we've come to expect from one.
There have been (and are currently) a few LED LCoS, but I've only seen single panel versions with contrast around 1000:1.
I wonder if a good 3panel version could still use the simplified design of RGB LEDs instead of splitting white via prisms.
The LED DLPs besides the consistency benefits you mentioned also become more efficient from using only the required RGB sources as they are required instead of blocking light with a colorwheel. They also become hardier from that lack of moving parts (a DMD can take a surprising amount of shock and abuse..as can fans). It is also fairly typical for them to use faster strobe times which further reduce RBE even compared to the 6X w1070 at 50Hz. The safe instant off ability is friendly as well as the seemingly endless number of strikes.
Beyond the lower lumens and different shape of the LED source, a focused light is a focused light and manufacturers are free to use whatever quality and style of lensing they please. The amount of options available as prices slide downward are pretty exciting.
Sort of on topic; can anyone explain how early in the light-path any lensshift/offset options need to be placed and why they are so often limited for DLP?
Ftoast is offline
Old 07-05-2014, 07:04 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
well, this has certainly been an amusing thread
wormraper is online now
Old 07-05-2014, 12:36 PM - Thread Starter
Bsims2719's Avatar
Quoted: 26 Post(s)
Originally Posted by Nicktx27 View Post
About as stupid as someone who thinks it's as easy as slapping some parts from a bin together. Seriously man, you need to take an Econ 101 course.
You need to take a couple of courses on manufacturing. I'm an engineer and I work in a manufacturing plant. I can't tell you that it for the most part it doesn't really matter what it is the cost to produce something is largely related to the volume being produced.
Take a Ferrari 458. From a manufacturing standpoint there is nothing really special about it compared to say a Toyota Camry. All the parts are produced the same way and all the pieces are assembled the same way. If someone were to build it at the volumes of a Camry the 458 would cost roughly the same as the 458.
All I'm saying with this thread is that the projector market needs a paradigm shift to increase volumes and lower cost. It's caught in this niche mode and needs to get out of it.
If they could make a small, light weight short throw projector they could increase volumes substantially and lower costs. Then the consumer gets a projector that is easy to install, produces a much larger image than a flat panel can provide and doesn't cost a crazy amount of money.
Bsims2719 is offline
Old 07-05-2014, 12:53 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
All my engineering, logistics and manufacturing course went fine for me. Seems you need a refresher.
Nicktx27 is offline
Old 07-05-2014, 03:06 PM - Thread Starter
Bsims2719's Avatar
Quoted: 26 Post(s)
Ahhhh logistics. That explains it. Not really engineering. Let me guess IE, IEOM?
Old 07-05-2014, 03:26 PM
Quoted: 24 Post(s)
But prices have been dropping, rather drastically. You're acting like there hasn't been any progress at all, despite falling prices, rising contrast ratios, shrinking sizes, and the huge leaps LEDs have made in the last few years. Just because the exact specific projector you personally want doesn't exist yet doesn't mean the industry has been sitting on their collective hands.
You keep switching between short throw and ultra short throw (which is a pretty big difference in terms of usability), but I have to ask... have you ever used one? The nature of firing light at a steep angle, rather than straight ahead, does not make installation easier in a lot of scenarios. It's much more demanding for placement and much less forgiving of surface imperfections. The upshot is that it doesn't require as much distance from the screen, which can work very well in small or awkwardly shaped rooms, but it's not the magic bullet for projector installation you seem to think it is.
Projectors will always be more complicated than standard TVs and monitors, just by the nature of having the light source and the screen separated from each other and relying on the user to match them up. You can make the process easier than it is, but never easier than a TV, which is why they're going to remain a niche as long as convenience plays a large part in purchases.
fierce_gt likes this.
sethsez is offline
Old 07-05-2014, 04:15 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
quality takes more time, and time is money. they don't hand build cars because they want to, they hand build cars because it ensures a highly level of quality when it comes to fit and finish.
same thing applies all over. in order to produce high quality optics, it takes longer for those lenses to be made. less room for error means more product needs to be recycled instead of sold too.
there is advantage to building in mass, but it's not a miracle cure that makes everything cheap.
fierce_gt is offline
Old 07-06-2014, 08:57 AM
Charles R's Avatar
Liked: 536
To my thinking you could literally give the best performing projector on the market to the overwhelming majority of the population and they wouldn't use it at all. It simply doesn't fit their lifestyle. Not unlike giving them a tank and expecting them to drive it over their current vehicle. It simply doesn't fit how they live... so much for volume discounts.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 07-06-2014, 11:39 AM
fierce_gt's Avatar
Liked: 1570
to build on this, the 'best' projector for the average person is going to be nothing like the 'best' projector for the movie enthusiast.
heck, we can't even pick a projector that's 'the best' for 2D and 3D. let alone one that's also the best for gaming, ambient light viewing, dark room viewing, watching sports, etc.
if you think 'projectors' are a niche product now, take away the options we have now by mass producing only one model and watch that market shrink even more...
Old 07-06-2014, 12:15 PM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
That's for sure. DLP is amazing for motion/sport, 3D and sharpness but average on contrast and black level. LCOS/SXRD is amazing for contrast and black level but average for motion/sport, 3D and sharpness.
Heck, it's the old "Fast, Good and Cheap - pick any two!" triangle all over again.
With time, iterative improvements on these projection technologies will hopefully drive these limitations down (along with costs, as we've seen with DLP).
But yes: this, coupled with almost-arbitrary requirements (low-ambient-light rooms, dark-colored paint-jobs, projectors requiring separated placement from projection screens) is going to keep home-based front-projection niche for some time to come...
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
Old 07-06-2014, 04:00 PM
PrimeTime's Avatar
Quoted: 552 Post(s)
Liked: 262
IMHO, the OP -- despite a professed familiarity with the manufacturing process -- is giving short shrift to the challenges and difficulties posed with cutting-edge designs by the engineers in the R & D department upstairs (or across the sea) from the factory floor.
OTOH, this mentality goes a long way in explaining the demise of domestic product development in favor of offshore quasi-clones where everything (including design engineering) is reduced to a commodity.
PrimeTime is offline
Old 07-06-2014, 09:36 PM
FendersRule's Avatar
What is the next "best bang for the buck" projector out there for $2,000? It seems like there has been a void. I bought an Epson 8700UB back in 2011 because it was hailed at the time. While a nice looking image, it eats bulbs every 800-900 hours. Already been through 5-6 since I bought it (most of them on Epson's dime). Had to send back my original projector to get a replacement due to a dust blob in the center of the screen after 5 months of use. Had to play with Epson for twice until getting a brand new one because they kept sending me refurbished crap (one with poor convergence and one that you had to focus each time using it).
The current 8700UB that I have has been great, but it's now starting to make a mechanical clicking noise when starting. Not sure what that means. It's probably going to destroy my resale value (who wants to buy something that makes a strange noise?) My bulb is nearing 800 hours and I have to now order a new bulb to keep one on hand. Another $260, can't wait.
I've been wondering if it's time to step up. But I only want to spend $2000. If technology has gotten better since 2011, where is my next $2000 projector that will spank what I have? I need to be able to mount it anywhere I want and adjust the picture wherever I need it on the wall without having to physically move the projector. I want something that will at least be "truly" rated by the bulb life (seems like Epsons eat bulbs way faster than their rated life), and I want dark blacks (Epson 8700UB or better). I want something with latency that is as fast, if not faster than the 8700UB for gaming (which isn't "excellent" but nor "bad"). Will $2000 get me something with 3D + glasses, and a free bulb like my last purchase?
If the answer is "yes", then I can get the next best thing that I want for $2000.
If the answer is "No", then the OP is dreaming of electric sheep.
FendersRule is offline
Old 07-07-2014, 09:42 AM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The Sony hw40es fits all or most of your requirements on sale for $2000 right now. No bulb or glasses (PS3 glasses work for under $20)
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Old 07-07-2014, 12:17 PM
Ftoast's Avatar
Liked: 624
I just realized the LED DLP hd91 has a full above/center/below vertical shift, along with horizontal lens-shift and 1.9:1zoom. I thought singlechip DLP wasn't even ABLE to have that sort of placement range.
Why don't more $2000+ DLPs have this kind of range?
Ftoast is offline
Old 07-07-2014, 06:56 PM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
Why the Epson has such a poor bulb life? Or something to do with your environement? The W1070 has rated 6000 hours in smart eco, and I've seen several real life claims to be pretty close, around 5000 hours mark. Bulb costs less than $100 from Aliexpress.
hotjt133 is offline
Old 07-07-2014, 08:31 PM
Seegs108's Avatar
Quoted: 4197 Post(s)
Liked: 2087
Because the cheaper DLP units use the cheaper and smaller .65" DMD. Once you step up to the larger higher performance .95" DMD the size of the optics needed to get the same placement flexibility as the HD91 is HUGE. Once you get north of $10000 you start to see greater placement flexibility with DLP projectors. The money is in the budget to use optics large enough.
Seegs108 is offline
Old 07-07-2014, 11:20 PM
Ftoast's Avatar
Liked: 624
That makes it sound like it's cheaper to produce such flexible optics for the smaller .65"DMD. Am I misunderstanding?
Ftoast is offline
Old 07-07-2014, 11:25 PM
Seegs108's Avatar
Liked: 2087
Yes, that's true, but you're rarely going to see that happen because the budget just isn't there to afford a "flexible" lens on your typical .65" DMD home theater projector. You don't need to go overboard on lens size to be able to get the same kind of flexibility LCD and LCoS projectors typically get with the smaller DMD. If you look at the size of those LCD and LCoS chips you'll see that they're also right around the .65" size. Typically speaking the LCoS and LCD projectors are in a higher price bracket compared to most .65" DMD projector so they too get better lenses which affords them better placement flexibility. The HD91 and Sharp XV-Z30000 are exceptions to the rule because of their far higher MSRP. They get larger, better, optics. There are drawbacks to making smaller sized chips. The smaller the DMD gets, the worse it's native contrast gets. Most .65" DMDs offer roughly 1200-1700:1 contrast and the larger .95" DMD offers anywhere from 2500-5000:1 contrast. Optical quality can also affect contrast too. Also, the smaller the DMD gets the harder it is for optics to focus on the DMD mirrors. You need better optics on the .65" DMD to get the same kind of sharpness a .95" DMD can get with less "high end" optics. This is typically why a .95" DMD projector has a much sharper image. It's easier to get better back-plane focus with something that's larger in surface area. But unfortunately the .65" DMD projectors get the short end of the stick because the price segment it's typically found in. They get poorer lenses because the manufacturing cost becomes too high for the price bracket the company plans to sell the projector in. So image sharpness, contrast performance, and placement flexibly all get exponentially worse as the price goes down, typically speaking.
Ftoast likes this.
Seegs108 is offline
Old 07-07-2014, 11:36 PM
Ftoast's Avatar
Liked: 624
That makes sense then..not that I have to be happy about it.
Has anyone found a tear-down video or something similar that shows the workings of the zoom and offset/shift lenses? It's be great to SEE the difference between LCD and DLP moving lenses. Even a simplified diagram would be nice.
Ftoast is offline
Old 07-08-2014, 05:48 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Yes, logistics isn't engineering. That's why I took engineering courses.
Nicktx27 is offline
