SP4805 owner is looking for a replacement. - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By kreeturez
  • 1 Post By Ftoast
post #1 of 5 Old 07-13-2014, 12:01 AM - Thread Starter
Roy
Roy's Avatar
I used to own a SP4805 and was very satisfied with the video quality, especially the black level, contrast ration and shadow details. I am looking for a inexpensive 1080P projector to replace it (I have sold 4805). From reviews, looks like a lot of budget projectors are not good at black level and shadow details. For example, SP4805 has a native 2000:1 contrast ratio which I can tell is TRUE. But reviews said projectors like 1070 has a 900:1 contrast ratio.
I wonder if you can recommend a replacement with comparable black level, contrast ration and shadow details. Thanks in advance.
Roy is offline
post #2 of 5 Old 07-13-2014, 07:09 AM
Ftoast's Avatar
Quoted: 1918 Post(s)
Liked: 624
What's the high end of your budget?
Around $2000 there are choices measuring 4000:1-6000:1 contrast, but cheaper than $1900 you're pretty much trapped in the 1500:1 and under zone.
I've heard the w1070 is around 1200:1 and can go higher if you don't mind things like brilliantcolor and less perfect white-balance.
Ftoast is offline
post #3 of 5 Old 07-13-2014, 07:30 AM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
Black levels on the W1070 are decent (but not spectacular), but contrast-wise, it's been measured at between 1500-2000:1 which isn't far off your requirement.
See:
http://www.hometheaterhifi.com/proje...the-bench.html
(Measured around 1500:1)
...and:
http://thewirecutter.com/reviews/the...000-projector/
(Geoffrey measured around 2000:1)
My guess is that's measured with SmartEco Lamp mode, which produces a degree of dynamic brightness along with extended lamp life.
The W1070 is around $700-$800
If you can stretch your budget to $2.5k, the Sony HW40ES will do even higher (5500:1); but you do pay for that increase... It's not the 'inexpensive' you're looking for.
I suspect the W1070 should comfortably beat out the SP4805 in most other respects.
Ftoast likes this.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #4 of 5 Old 07-13-2014, 07:42 AM
Ftoast's Avatar
Liked: 624
Most projectors will have to be mounted a lot closer than that 4805 and will be a lot brighter which may also affect the perceived contrast with the higher black-levels. A NDF or low-gain screen can help take things down if you prefer it dark and similar to the 4805.
kreeturez likes this.
Ftoast is offline
post #5 of 5 Old 07-13-2014, 08:38 PM
Ftoast's Avatar
Liked: 624
Thanks for the contrast links Kreetures. That makes more sense as the w1070 had better contrast when I was comparing it to my LG and P300 and the 300 measures around 1100:1-1200:1. Granted, I only had the contrast below 47-49 once to try someone else's settings, so I was mostly enjoying the Benq with most/all of its CR to see how big the difference would look.
Ftoast is offline
