Benq W1200 - new lamp, only greens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-18-2014, 03:02 AM - Thread Starter
Liked: 0
Hi Guys,
After almost 2 years my lamp died so i ordered on eBay a replacement bulb (no casing).
After whole operation when i switched on the projector it started ok, displaying the Benq purple logo but when got the signal from my laptop(computer connection, no hdmi) there are only greenish kind of colours, no red, no white etc...
Would it mean that there is something wrong with the new lamp? What else should i check?
Nothing has changed in my setup. I don't know much about projectors but weird thing to me is that the Benq logo gets displayed correctly during a startup...
Any help would be much appreciated...
Lukasz
Lukasz83 is offline
post #2 of 3 Old 07-18-2014, 02:38 PM
rekbones's Avatar
Quoted: 466 Post(s)
Liked: 238
Did your old lamp explode, there might be loose glass in the color wheel. Your problem sounds like color wheel related.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 07-18-2014, 06:51 PM
airscapes's Avatar
Quoted: 381 Post(s)
Liked: 304
how is your laptop connected, are you using vga to component RGB rca plugs? Check them you may have the hooked up wrong.. been there done that..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
