Which projectors should I look at? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-18-2014, 09:35 AM - Thread Starter
ChldsPlay's Avatar
Quoted: 609 Post(s)
Liked: 317
I'm looking at either a 120" or 130" screen (give or take), at a distance of 14 to 18 feet (depends on which way I arrange the room). The room will be light controlled with no light from the outside, black ceiling, and dark matte walls.
I will have a 2.35 CIH screen, so I want a zoom memory function.
3D will be used and quality is important, but not priority.
There will be some gaming, but absolutely no first person shooters. Some 3rd person shooters maybe, and other action games (Think Uncharted, God of War, Last of Us, etc.), and role playing games. Again, quality is important, but gaming isn't the priority.
Exact budget is uncertain, but I can go over $3,000 if necessary (wasn't sure if I should put this here or the over $3,000 forum).
ChldsPlay is offline
post #2 of 2 Old 07-18-2014, 03:28 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The only projectors with memory zoom in your price range are the JVC's and the Panasonic 7000/8000. Some of the older JVC's can be had for a little under 3k and the Panasonic's around 2.5K
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
