Help with Projector purchase - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-25-2014, 06:05 AM - Thread Starter
Liked: 0
Hi all, I am purchasing my 1st ever projector and would love any assistance. I am using a 120" screen. Will use it for sports viewing, some movies, and some gaming. Room is pretty dark, but does have some light during the day. Trying to stay below $3000. Thanks
Bigeasymike is offline
post #2 of 3 Old 07-25-2014, 08:47 AM
AV_Integrated's Avatar
Quoted: 1094 Post(s)
Liked: 794
Please answer the following questions:
1. What is the size of your room - L/W/H?
2. What are the wall colors?
3. What is the ceiling color?
4. What is the floor surface and color?
5. Is this a dedicated theater space, or part of a 'rec room'?
6. Basement? First floor? Other?
7. What is your ability to control lights in the room (dimming)?
8. What is your ability to truly control outside ambient lighting coming into the room?
9. Do you have an existing surround sound system?
10. If no sound system, is there a separate budget for that, or is that included in your 'price'?
11. Do you plan to install it all yourself?
12. Is your budget specifically for the projector, or is it for every single thing you need, plus installation?
13. What is your viewing distance (eyes to screen)?
14. Do you have cabling run for the projector and power already?
15. What distance can the projector be mounted from the screen (any distance, 10', 25', etc.)?
16. Do you have a mounting preference or demand? Ceiling mounted? Rear shelf mounted? Anywhere anyhow mounting?
17. Do you already have this 120" screen?
18. How did you determine that 120" diagonal was the right size for your viewing distance and room?
19. How much do you plan to use the projector?
20. How much gaming/movies/sports viewing do you intend to do as a percentage?
There may be more questions, and there are some nice projectors under $3,000 that will work well at that screen size, but you should really answer the questions first so that a proper recommendation can be made.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 3 Old 07-26-2014, 05:21 PM - Thread Starter
Liked: 0
1. What is the size of your room - L/W/H? 20x20x 11
Dark grey
White
Pine - natural
Dedicated
Man cave 2nd floor above carport
Ability to dim
Pretty good
Yes
No
Budget is for projector only. I would love any feedback on screen as well. Figure sub $500
13. What is your viewing distance (eyes to screen)? 10-12ft
Yes
Any under 20
Anywhere
No
Did not. Just wanted big
A lot during football season. All other times of the year strictly for movies and some gaming
Football - 50% Movies 30% gaming 20%
