Inland 301 Ceiling Projector Mount for BenQ W1070? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-27-2014, 12:09 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 0
My wife works at a home office of a computer store that sells this particular projector mount. So she bought it for me recently thinking it was a universal mount. Does anyone know if this mount will work with the BenQ W1070? Just want to make sure before the installer comes out to do it.
SteveS78 is offline
post #2 of 2 Old 07-27-2014, 07:42 PM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
Should be universal. I'm using one with an Acer 6510hd. Just make sure you have the correct mounting screws. I had to buy 3 screws to fit my mounting holes, but the Inland came with other size screws.
Sonyad is online now
