I'm going to be in the market for my first pj in the next 6 months - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-31-2014, 11:39 AM - Thread Starter
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
so I'm hoping to be ready to purchase a projector somewhere between October and January. My price point is in the 2500 - 3000 dollar area. So for the last year I've been pretty set on getting an epson 5030ub. Now with cedia around the corner I'm having second thoughts on what pj I will end up with. I'm only going to have one shot at getting the right projector (at least for quite a while) so I'd like to make the best choice I can. My room will be fully light controlled but not a dedicated "theater" so to speak. We would be split between watching movies and Football and Hockey games. So with these 2 types of viewing habbits I've been really torn on what to do regarding my screen ratio choice. The epson does not offer any type of lense memory so really that would leave me with either manually re zooming any time I change the format of the media we are watching. Or I build my own masking system wich I'm not really opposed to. Now I see projectors like the panasonic 8000 that has lense memory but it's an older projector and little things like the 3d glasses are not RF kind of bother me. So with the new crop of pj's coming out are there other models I should keep an eye on in the 2500 - 3000 dollar range? One that will handle both 16:9 and 2.35 content would be great! If the epson 5040ub adds that then I'd most likely go that route but I'm thinking they will.
Thanks in advance for any input you may have!
gec5741 is online now
post #2 of 4 Old 07-31-2014, 12:27 PM
kreeturez's Avatar
Quoted: 471 Post(s)
Liked: 354
Other than the Panny, there aren't all that many projectors in this price range that offer lens memory.
CEDIA is just a month or so away - and you're not ready to buy right now in any case - so let's see what companies like Epson release first.
They (or any other exhibitors at the event) might have something that fits your needs.
Then take it from there
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #3 of 4 Old 07-31-2014, 12:35 PM - Thread Starter
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
Sound advice thank you. I'm just anxious I suppose I am really looking forward to Cedia to see what's coming down the line! Like you said I'll then have a good idea of what I'm looking at as far as options.
post #4 of 4 Old 07-31-2014, 02:02 PM
Ftoast's Avatar
Quoted: 1919 Post(s)
Liked: 625
Also, at your price range (and the mention of the 5030/5040ub) keep an eye on the Sony hw40es which has been mentioned as a slightly better alternative to the Epson at an often lower price.
But like kreetures said, a lot can happen in 6months between new model releases and older model price drops.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
