Benq W1070 upside-down on a shelf - Best way to adjust? - AVS Forum | Home Theater Discussions And Reviews
Old 08-02-2014, 08:33 AM - Thread Starter
Liked: 1
So, I have a Benq W1070 laying upside down on a shelf.. I wont mount the projector on the wall, or under the shelf so you can skip those ideas..
I want tips on how to adjust my projector to my screen since its not flat on the top.. Any ideas?
skuum is offline
Old 08-02-2014, 09:20 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
This is a case of a situation that would be almost impossible to give advise for without seeing exactly what you're talking about. Can you post a picture or two? It would make a world of difference.
ben38 is offline
Old 08-02-2014, 09:26 AM
Ftoast's Avatar
Quoted: 1927 Post(s)
Liked: 626
If you've ever seen one of those dashboard beanbags that you can use for a GPS or cellphone..I think they're silly in general, but this might actually be a justifiable use situation. You can usually find them at radioshacks or department-store car or electronics sections..I want to say around $15-35. Stable, malleable, and heat resistant!
You might have to stuff something like a small doorjam or shim underneath the front or back to get your vertical keystone just right.
If projectors didn't get so hot I'd suggest trying to use the packing material it came with that held it still inside the box, but I'm afraid for what it might do to the styrofoam.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
Old 08-04-2014, 07:38 AM
Erasmus354's Avatar
I would suggest using some Sugru to mold some feet on the top (bottom for you) of the projector. This will allow you to have a stable surface.
Erasmus354 is offline
