HDMI Cable Run To Projector? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By ocelittle
  • 1 Post By Nicktx27
  • 1 Post By butie120
post #1 of 17 Old 08-07-2014, 08:50 PM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
I'm building out a theater right now, have an Epson 8350 that will be mounted on the ceiling about 11 feet from the screen. Receiver/Components will all be under the screen along with the Center Speaker. All I can think of is to buy a 25' cable and run it along the floorboard (in a cable management piece to hide it), but I'm not sure how to get it UP to the projector. The projector isn't at the back of the wall (it's more in the center of the room).
Any thoughts?
Loudominos likes this.
ocelittle is offline
post #2 of 17 Old 08-07-2014, 09:11 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Why not through the attic and down the wall?
Nicktx27 is offline
post #3 of 17 Old 08-07-2014, 09:29 PM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
The theater is on the main floor of a two-floor house. No attic above it...we could technically run it through the ceiling I suppose.
post #4 of 17 Old 08-07-2014, 09:31 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Might be more hassle. Carpet or wood/tile flooring?
Nicktx27 is offline
post #5 of 17 Old 08-08-2014, 01:41 AM
ALtlOff's Avatar
Quoted: 1042 Post(s)
Liked: 500
^^This^^
If you have carpet, there are companies that make flat HDMI cables that you can run under carpet that you barely notice when walking on it and can't really see a bump at all.
ALtlOff is offline
post #6 of 17 Old 08-08-2014, 06:39 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
I actually have a flat 25' hdmi cable from Monoprice that I've been using for a few years. Works perfectly.
Nicktx27 is offline
post #7 of 17 Old 08-08-2014, 09:05 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
"Could technically"??? I'd wager 75% of the theaters on here have a cable (or two) in the ceiling
Which way do the floor joists run? Parallel or perpendicular?
NickTheGreat is offline
post #8 of 17 Old 08-08-2014, 09:11 AM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
Not sure which way they run. We just got the keys. If I were to run it under the carpet, how do I get it to the projector? That's my only real concern. Ceiling mounted projector and I want the room to look clean.
post #9 of 17 Old 08-08-2014, 09:32 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Run the flat cable under the carpet then up the wall and pull out where you need it. Without seeing the room that's the best I can really offer.
jamese777 likes this.
Nicktx27 is offline
post #10 of 17 Old 08-08-2014, 10:18 AM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
Sorry, my thought regarding getting up to the projector is keeping the wire tidy on its journey up the 9 feet walls.
The only thing I can think of (other than running it up the wall and then through the ceiling and drop to the projector, which is still possible) is using cable runs (similar to this: http://www.monoprice.com/Product?c_i...seq=1&format=2) to keep it looking tidy.
post #11 of 17 Old 08-08-2014, 10:23 AM
quad4.0's Avatar
Quoted: 132 Post(s)
Liked: 88
quad4.0 is offline
post #12 of 17 Old 08-08-2014, 10:27 AM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
Those second ones are pretty nice, considering the walls are grey...i'd need two, but that's probably fine. Cool find, thanks!
post #13 of 17 Old 08-08-2014, 11:00 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Why don't you do like I recommended and run it in the wall? How far is it from the wall?
Nicktx27 is offline
post #14 of 17 Old 08-08-2014, 11:14 AM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
It will be about 11' from the receiver (plus the 5 or so feet to the center of the room and from the center of the room to the walls).
The issue with the wall directly to the projector is that it's not near the wall, it's in the middle of a much longer room (room is about 21' long, projector will be around the 11' mark). So I could run up the wall, but then it has to go the 6 or so feet to get to the projector itself, wasn't sure which way would be the best.
post #15 of 17 Old 08-08-2014, 11:18 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Ok. You may want to either draw a diagram or take a picture of the space to allow us to help better.
Nicktx27 is offline
post #16 of 17 Old 08-08-2014, 11:27 AM - Thread Starter
ocelittle's Avatar
Quoted: 48 Post(s)
Yeah I will do that for sure, I realize that would help a lot more than my weak attempts at explaining it
post #17 of 17 Old 08-08-2014, 03:04 PM
butie120's Avatar
Quoted: 340 Post(s)
Liked: 67
I run my 35" HDMI cable in the ceiling and it worked beautifully. Mine was an ideal scenario in that the joists ran perpendicular in regards to my projection screen. I just ran them by grabbing up through some light canisters and feeding it down next to one of the joists. My AV cabinet is in the back of the room so I then ran the cable down against the wall using Wiremold which covers the cable. You can then paint the wiremold, and bam, no one would ever notice it's going down the wall unless they inspect the wall.
ocelittle likes this.
butie120 is online now
