On wall cable management? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-08-2014, 09:36 AM - Thread Starter
pstam's Avatar
I've got cables running up a wall (just two, an HDMI and a power cord) and then out a boom to my PJ. Any recommendations for how to clean up the look? I'm putting my bed right against them too, so I don't want to accidentally tug on the cables while I'm sleeping or doing anything else.
Cable management suggestions?
pstam is offline
post #2 of 8 Old 08-08-2014, 09:41 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Try these. I used them in the last rental I had for speaker wires. They come in varying lengths and sizes.
http://m.homedepot.com/b/Electrical-...t/N-5yc1vZc64e
Nicktx27 is offline
post #3 of 8 Old 08-08-2014, 10:07 AM
akm3's Avatar
Quoted: 81 Post(s)
Liked: 26
Why not fish the cable through the wall and get a nice wall plate to pass the cables through? It's not very hard and it makes it looks 1,000x better.
If you purchase some glow rods and a magnepull device, you can fish cable like a pro and you'll find yourself using it everywhere.
It's hard to love Martin Logans and 2.35:1 CIH at the same time...
akm3 is offline
post #4 of 8 Old 08-08-2014, 03:17 PM - Thread Starter
pstam's Avatar
I should have mentioned I'm renting right now and can't cut into the walls to install plates. It's gotta be on wall.
pstam is offline
post #5 of 8 Old 08-08-2014, 03:37 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
Yes, that is good info to have. Use the cable covers. I did in the last place I rented. Use the command hook adhesive strips instead of screws.
Nicktx27 is offline
post #6 of 8 Old 08-08-2014, 07:17 PM
akm3's Avatar
Quoted: 81 Post(s)
Liked: 26
This makes sense!
No advice in that case, it's hard to make it look nice.
akm3 is offline
post #7 of 8 Old 08-09-2014, 02:38 PM
b15nut's Avatar
I just ordered a couple of kits from monoprice. 10' for less than $9.
b15nut is offline
post #8 of 8 Old 08-09-2014, 08:03 PM
AllenA07's Avatar
Quoted: 683 Post(s)
Liked: 554
I use channel covers. I take the time to paint them so they match the walls. Like you I'm also renting so I can't make as many modifications as I would like. The painted covers aren't going to make my setup an AVS theater of the month, but it looks better then bare wire.
AllenA07 is offline
