Looking for a 1080p gaming projector that fits my current setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ftoast
post #1 of 3 Old 08-10-2014, 02:41 AM - Thread Starter
Liked: 0
Question Looking for a 1080p gaming projector that fits my current setup
Hi there,
I'm new to this board, I usually only used the german hififorums but these are not as active as your AVForums here
I currently own a BenQ W700 and use it for gaming with a high end gaming PC in my home theatre. Since i have some spare cash over right now, i want to buy a fullHD projector to replace the W700. But there are some specific requirements that need to be taken care of.
First, this is what my new projector should have:
-the new projector needs to have a resolution of 1920x1080 a.k.a. FullHD
-my budget is 700€(that's about 920$)
-2xHDMI slot
-low input lag
-generally a good/very good ability to be used for gaming
Second, these are the current circumstances:
-my screen allows a picture with maximum dimensions of 199cm x 112cm
-the projector HAS to be able to project that screen size from a distance of about 324-327cm(the W700 sits on the ceiling and i'm not able to move the mounting)
-die middle of the lens is 45cm away from the ceiling and the top of the picture is 65cm away from the ceiling(->offset?)....but i would be happy if i could reduce the distance between ceiling and projector in the future
These are the projectors I already looked into:
-BenQ W1070: For the W1070 i would have to move the mounting, which is not possible for me.
-Optoma HD131XE: In my opinion that is a good choice due to low input lag and currently low price. But i have read that the colors aren't that good.
-Optoma HD25e: What is the difference between that one and the HD131XE?
What OTHER options are there to consider?
Here are two pictures of the current situation in my room(#1 is from standing under the projector and looking at the screen, #2 is from standing in front of the screen) :
http://i.imgur.com/su10u2y.jpghttp://i.imgur.com/q8Lydf8.jpg
Please recommend some projectors that would fulfill my circumstances.
Thank you guys and I'm sorry for any trouble my english skills create
Best regards
Poly
Polypropylen is offline
post #2 of 3 Old 08-10-2014, 07:30 AM
Ftoast's Avatar
Quoted: 1940 Post(s)
Liked: 628
You'll want to stay DLP for the best motion and lowest lag. There are a few models though the w1070 is quite a ways ahead of everything else..the 131xe though less accurate by a fair amount is still slightly more accurate than most other inexpensive DLPs. The 131xe and hd25e are the same projector in a different color case. At one point they were even running the exact same firmware updates. The slight difference in listed specs is just a little made-up difference to make it more believable that they are different so some will be tricked I to buying the more expensive one. It's exactly as weird as it sounds.
Polypropylen likes this.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 3 Old 08-10-2014, 07:33 AM - Thread Starter
Liked: 0
Thanks for the reply
AND thanks for the heads up on the HD25e! The HD131XE is currently available for only 560€, die W1070 would be +100€ but sadly, I'm not able to fit it into my room.
So besides the HD131XE there is no competition around the 700€-mark?
I just read something about the Viewsonic PJD7820HD , anything on that one compared to the HD131XE? It's at about 600€.
