Projector for my new theater room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-10-2014, 02:26 PM - Thread Starter
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
I hate to create one of these noob type threads, but this area is totally new to me, and I have no idea what to look for. So I am seeking guidance from those more experienced.....
The projector will be ceiling mounted. Will be using a roll up screen, I think it's about 80-85", bolted to the wall. The wall is about 10 feet away from where the projector will be mounted. Room can be totally blacked out.
Will only be used for movies/TV.
Would like to keep the budget <$2500. My main concern is image quality, black levels. I am coming from a decent plasma. 3D would be optional. Not a necessity.
Thank you for you help.
the_abbot is offline
post #2 of 6 Old 08-10-2014, 03:19 PM
Ftoast's Avatar
Quoted: 2243 Post(s)
Liked: 707
The best blacks within your budget will come from the Sony hw40 or Epson 5030ub. They are pretty close in blacks but the Sony has been consistently rated as the better and more accurate image while the Epson has smoother 3D. It sounds like the Sony would be the better fit for your situation.
It will easily make that size screen from that distance, it runs very quiet and it is pretty much the best available under $3500 (where the hw55 and JVC's tend to start).
If possible, I'd look for getting a fixed-frame screen because rollups tend to get waves and wrinkles within a year or two. If a solid frame would work but is out of budget right now, another option is painting one onto a smoother wall with flat-white interior wallpaint. It's incredibly easy and inexpensive for the fantastic results it gives.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 6 Old 08-10-2014, 04:23 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Unlike a TV, your room color can destroy your contrast. Dark colors no less than 5 ft out from the screen on the ceiling wall and floors is minimal treatment for reflected wash out prevention. Black velvet is the ultimate but any flat dark color is better than white.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 6 Old 08-10-2014, 04:45 PM - Thread Starter
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Thanks! Didn't think of just using the entire wall.
I will definitely use a dark color paint. I am planning on repainting the entire room a dark color.
post #5 of 6 Old 08-10-2014, 09:40 PM - Thread Starter
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
The JVC RS46 looks like it might be a lead contender....
post #6 of 6 Old 08-11-2014, 12:43 AM
Ftoast's Avatar
Liked: 707
If there's a new JVC in your budget, YES. They'll have black levels that nothing else can touch.
Ftoast is offline
