Purple spot problem Panasonic pt-ae3000 - AVS Forum | Home Theater Discussions And Reviews
Old 08-28-2014, 05:02 AM - Thread Starter
Liked: 0
Hello! What you think? I cant see spot if im shooting basic red green or blue. Only with white color or on movies. Is this dust or polarizer problem? Or maybe something else? Projector is over 5000h old. Thanks a lot!
vivanto is offline
Old 08-28-2014, 05:15 AM
GMC
GMC's Avatar
You might try searching in the PTAE threads in the >$3000 forum. I know I've seen that before. Maybe the 1000.
GMC is offline
Old 08-28-2014, 05:59 AM - Thread Starter
Liked: 0
I already chek those. its never ending thread. I cant find samekind problem. I just hope someone can identify this, so I know should I start clean it from inside...
vivanto is offline
Old 08-28-2014, 09:41 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
It's a incidence polarizer problem, not uncommon with the 3000. A dust blob is usually an irregular shaped object that becomes better defined when you focus the lens on it.
This involves sending it in for repair, finding parts for this projector will be difficult if you decide to try to repair it yourself.
However here is a link to the service manual.
ftp://helpedia.com/pub/temp/datashee...U_%5BSM%5D.pdf
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 08-28-2014, 04:41 PM - Thread Starter
Liked: 0
If I found right part I will change it by my self.
vivanto is offline
Old 08-28-2014, 05:04 PM - Thread Starter
Liked: 0
And hey what you think is it green plate?
vivanto is offline
Old 08-29-2014, 03:27 AM - Thread Starter
Liked: 0
if its only problem whit polarplate. part is avalable. I try first clean it. if its not helping I will order plate and repair by my self
vivanto is offline
Old 08-29-2014, 07:13 AM - Thread Starter
Liked: 0
Well, i take a green polarizer plate away. I cant see is there any problems on this filter? What you think? I found place where to order new but its cost, so I need to be shure what is wrong. Can this be lcd panel problem? well that gona cost like helll...
I clean everything so good what I can. Then i put all parts back and start up projector. I can see the problem is still there. but maybe not so bad than its use to be. Or its looks maybe littlebit difrent...
vivanto is offline
Old 08-29-2014, 07:15 AM - Thread Starter
Liked: 0
Plate was there litle bit sideways. Can that make problems. Service manual ask put it back like it use to be.
vivanto is offline
Old 09-01-2014, 02:06 PM - Thread Starter
Liked: 0
I try to use projector without polarizator plate. first green then red, and finaly blue. I can see purple whitout any filter. Is there any other filters what can cause this? Or do I have bad luck and this is LCD panel problem? Or maybe lamp bulb? Its quite old. Almost 4000h old.
vivanto is offline
