Projector mounting question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By dreamer
post #1 of 4 Old 08-28-2014, 07:36 PM - Thread Starter
HulaBBS's Avatar
My living room ceiling slopes from 10" feet to around 7 feet where my seating area and ceiling mounted projector is mounted. It's 12" feet from lens to 110" firehawk fixed screen. Becuase of this my projector lens is around 6'6 feet off the ground so it points at the screen and with just a little angle up and small keystone I have the image squared and what looks to be a focused image. In a perfect world I would have the projector higher then the screen but my room can't accommodate this. So what drawbacks or issues does this present?
Thanks for any insight.
HulaBBS is offline
post #2 of 4 Old 08-28-2014, 09:41 PM
Ftoast's Avatar
Quoted: 2197 Post(s)
Liked: 697
What projector (brand and model, please) are you using?
If you're using a model with adjustable offset it won't do anything negative for the image (though some DLPs can have contrast raise or lower somewhat depending.
If you're using a projector that only has digital keystone correction you'll be losing and rescaling some of your resolution, especially at and near the top of the screen. The more noticeable negative is that straight vertical lines and shapes become a bit jagged and pixely-looking from the rescaling.
If you happen to be using a 720p projector that uses diamond shaped pixels instead of the usual squares this jagged look from rescaling doesn't seem to happen near as visibly.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 4 Old 08-28-2014, 09:53 PM
dreamer's Avatar
Quoted: 1046 Post(s)
Liked: 315
If you are having to use digital keystone correction, you are throwing away the 1 to 1 pixel mapping and blurring your image.
You might consider tilting the top of the screen out from the wall so its surface is square to the projection light path again. Or lower the screen on the wall so you don't need to tilt the projector. Or swap your room around so the screen is on the 7' wall and the projector and seating are on the 10' wall. Acoustically, you would be better off with the seating under the vaulted end of the ceiling. The way you have it, sound from the front speakers is hitting the viewers twice -- direct from the speakers and again reflected off the ceiling a split second later.
Ftoast likes this.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #4 of 4 Old 08-29-2014, 04:31 PM - Thread Starter
HulaBBS's Avatar
Thank you both for the replies.
This sounds like I need a pro installer. Anyone in Orange County,CA can PM me?
HulaBBS is offline
