Best Short Throw Projector? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Ftoast
  • 1 Post By Ftoast
  • 1 Post By jdaghir
post #1 of 7 Old 08-31-2014, 11:29 AM - Thread Starter
Liked: 0
Hello guys, first post here... Great forum by the way!... Well, I'm wondering which one short throw projector would be the best choice in terms of image quality (mainly contrast/deep blacks) under $5,000. I have an small room and i wish to project a 120 inches screen from 6.5ft. I know the Benq 1080ST would do the job, however i'm not satisfied with its low black levels
I just can't find a projector that fills my needs here exposed. Help me plz!
(Sorry for bad english, i'm from Brazil)
Thiws is offline
post #2 of 7 Old 08-31-2014, 06:22 PM
Ftoast's Avatar
Quoted: 2158 Post(s)
Liked: 678
It's likely that the only way you'll find a better looking short-throw than the w1080 is if someone reputable makes a LCoS-ST..which I haven't heard of. Now I'm curious as well. Sounds like you've got the proper budget for it if it exists.
Thiws likes this.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 7 Old 09-01-2014, 08:09 AM - Thread Starter
Liked: 0
Well, i think i'll have to wait 4k projectors to become more popular. I hope some manufacturer be interested to release a better short throw 4k projector... Sure i'll have the budget for it, its gonna be like shut up and take my money! lol...
Thx for the reply!
Thiws is offline
post #4 of 7 Old 09-01-2014, 09:19 AM
Ftoast's Avatar
Liked: 678
There's a goofy but proven to work (to some extent) alternative of getting a good projector and putting a camera zoom-lens in front. I'm not sure how much it would degrade the image but it looked really neat in a YouTube video..didn't seem to distort the image at all. I think the user said the lens was $80 or so.. that plus a nice theater projector in the $2500-3500 range might be your strange yet functional ticket.
Thiws likes this.
Ftoast is offline
post #5 of 7 Old 09-01-2014, 03:01 PM - Thread Starter
Liked: 0
Hmm very interesting... Could you post the link of the video plz?
Thiws is offline
post #6 of 7 Old 09-01-2014, 09:14 PM
Ftoast's Avatar
Liked: 678
Here's the thread with the discussion and video:
Question About Wide Angle Lens and My Projector
Ftoast is offline
post #7 of 7 Old 09-03-2014, 08:46 AM
jdaghir's Avatar
You can also point the projector away from the screen and bounce the image off of a first surface mirror to effectively increase the throw. That's what I do with my Infocus IN72. A first surface mirror eliminates the slight double reflection you would get with a regular mirror, but you can certainly use a regular mirror to determine the correct size & location before buying a first surface mirror.
Ftoast likes this.
jdaghir is offline
