HELP - Vibrations from AC unit shaking projector - AVS Forum
post #1 of 3 Old 08-31-2014, 03:46 PM - Thread Starter
Liked: 0
Exclamation HELP - Vibrations from AC unit shaking projector
Greetings,
I got my Sony VPL-HW40ES mounted on a Peerless mount, lagged into a joist and when the AC unit runs I get some vibration in the picture.
The AC unit is about 8 feet away and in the attic.
Some kind of vibration isolation? Rubber bushings some how? Tie the joist to others with plywood?
I'm amazed with the PJ when it's not vibrating ...
Jason
Mayhem_702 is offline
post #2 of 3 Old 08-31-2014, 08:44 PM
Liked: 0
For a cheap solution, you could get a hockey puck or two and drill a hole to bolt it to the ceiling. Then a pair or so to bolt up to the projector.
Press_Corpse is offline
post #3 of 3 Old Today, 03:12 PM
grendelrt's Avatar
I am having the same issue, I have to check to see if its the screen or the projector that is shaking. If it is the projector I am going to try to add some rubber grommets to the 4 feet that attach the projector to the peerless mount. The vibrations are pretty small so I am hoping that will be enough.
grendelrt is online now
mount vibration , projector
User Tag List
