SONY 1080P SXRD LED LASER Projector IFA 2014 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-07-2014, 02:04 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
https://translate.google.fr/translat...er-ifa-2014%2F
SONY is taking everyone by suprise and demonstrate a new 1080p led laser sxrd mini-projector at IFA 2014.
kraine is offline
post #2 of 4 Old 09-07-2014, 05:23 AM
Ftoast's Avatar
Quoted: 2197 Post(s)
Liked: 697
Crosses fingers that it isn't another single-panel LCoS like the older Aaxa units and that it beats the contrast of Sony's expensive wall-hugger. It does look like a pretty large device so I'd have to assume it'll be 3-panel.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
post #3 of 4 Old 09-07-2014, 05:04 PM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
? No it won't.
Epson is releasing similar as well. These will probably be 10k+. Don't really belong in this forum.
Verge2 is offline
post #4 of 4 Old 09-07-2014, 08:10 PM
Ftoast's Avatar
Liked: 697
That fridge picture looked like such a casual use for such an expensive device. Not that I don't believe you about the price, it's just weird to show a ~$10,000 cube stuck high on a wall to project a 20" diagonal of some snapshots.
