Help setting up system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-15-2002, 07:29 AM - Thread Starter
Mbuna's Avatar
Hello!
I just bought a project, a Phillips LC4433, and want to get some input on how to set it up for the best performance.
I plan on running everything through my Sony receiver, so I'll have DirecTv, standard cable, VCR, and DVD going into the receiver.
From there out to the projector.
My question is what cabling should I use to connect everything?
I think I have the following options for my components:
VCR: composite
Cable: composite
DVD: composite, svideo, optical
DirecTV: composite, svideo
The project accepts svideo or composite.
The receiver has three video inputs, so I will likely setup DirecTV, DVD, and VCR as the three inputs, and run regular cable through the VCR.
So please give me some thoughts on what would be the best way to connect everything.
Sean
Mbuna is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
