DLP in commercial (bar) application - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-20-2002, 12:56 PM - Thread Starter
jonvan's Avatar
Have a client looking for a projector. His freinds who own bars say they have had bad luck with DLP projectors because of all the constant smoke (even with smok-eaters). They told him to stay away. I really want to set him up with something reliable, as it relates to this. Any of you use a projector in this scenario?
Jon V.
jonvan is offline
post #2 of 5 Old 09-20-2002, 01:19 PM
dgetson's Avatar
I'd say that in a bar, your best bet would be with an LCD. Just because typically dlp's have lower light output. LCD brightness may be needed to cut through the smoke, etc.
Just my opinion.
dgetson is offline
post #3 of 5 Old 09-20-2002, 04:56 PM
BJM
BJM's Avatar
Check out the new NEC LT260. It has a sealed optical light path and NEC brochure mentions the advantages of this for
"dusty environments like classrooms (chalk), military field operations, or smoke filled rooms, bars or restaurants."
http://www.necvisualsystems.com/corp...re_final.1.pdf
The 2100 lumens should be plenty in a dimly lit bar. Definitely worth looking into. There are some good comments in this forum already on this projector and 1 or 2 people have already purchased one.
Brent
...... There is no spoon
BJM is offline
post #4 of 5 Old 10-05-2002, 11:02 AM - Thread Starter
jonvan's Avatar
thanks for the info on LT260. Talked with NEC at show and color wheel is not sealed however.
Does anyone have a DLP IN USE at a bar?
jonvan is offline
post #5 of 5 Old 10-07-2002, 07:18 AM
Floppo's Avatar
One trick that may help is to build a hushbox around it and direct airflow from the AC into the box. The air preasure will keep the smoky air out of the hushbox as well as help keep it cool. In theory atleast.
Chris
Floppo is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
