Ae-200, Ae200 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #31 of 52 Old 10-07-2002, 08:44 AM
cpc
cpc's Avatar
The scenes which show screen door the most are scenes with light areas. Sounds like the 200 is quite cool. Are you aware of anyone else in NA who has ordered one?
cpc is offline
post #32 of 52 Old 10-07-2002, 09:38 AM
DRS
DRS's Avatar
One question, how is the noise level in low power lamp mode?
DRS is offline
post #33 of 52 Old 10-07-2002, 10:14 AM
Mike Lindberg's Avatar
I ordered one. Stupid bank of mine didn't wire the money till today, so it should be here by Thursday. I won't have a screen yet, and will be projecting on my cream-colored (blech! :mad: ) walls for a few days.
I may throw some printer paper up to get an idea, though. ;)
-Mike Lindberg-
Mike Lindberg is offline
post #34 of 52 Old 10-07-2002, 12:55 PM - Thread Starter
jeffreyoian's Avatar
The fan is not loud at all.
jeffreyoian is offline
post #35 of 52 Old 10-07-2002, 01:33 PM
rlindo's Avatar
Quoted: 703 Post(s)
Liked: 526
Congrats on the new toy and I hope you have lots of hours of enjoyment with it.
As for the whole screendoor thing, hey, if you can't see it, DON'T even waste a second of your time on trying to look for it. MY advice is to jsut sit there, enjoy your movies and forget some of the stuff you have read here. Some people here are too focused on finding problems or pointing out negatives instead of actually using their projectors to do what it was bought for, which is watching movies.
rlindo is offline
post #36 of 52 Old 10-07-2002, 03:33 PM
cpc
cpc's Avatar
I am eliminating my balance on my credit card [well, one of them anyways ;) ] in the hopes that I can afford the AE200 in the next little while.
Hey jeffreyoian keep enjoying you PJ over there in Minnisota :)
cpc is offline
post #37 of 52 Old 10-07-2002, 04:08 PM
DRS
DRS's Avatar
can you compare it to anything? Did you hear the ae100 previously?
DRS is offline
post #38 of 52 Old 10-07-2002, 08:45 PM - Thread Starter
here is the deal boys. I don't have a screen. I just use a white wall. It is great. In a few weeks I am going to be able to put the ae300 side by side so i will post a thread about that when i can. But I now using the regular RCA inputs for TV and I love it. I think the colors are great and everything is just as I wanted it to be. I can't hear any fan noise at all. She is about 8 feet in the air though. I have seen many projectors. But when you can't see them side by side I don't think it is easy to see what is what. I had this thing at like 175 inch diag. and i thought from about 15 feet back it looked super. I just can't say a bad thing about it. Well time for another movie. Air Force one it is.
post #39 of 52 Old 10-07-2002, 08:58 PM
Xander's Avatar
jeffreyoian, if you could access to a friend with a good digital camera, it would be great to see shots taken (of the same shot) at 6", 12", 6ft, 12ft, 15ft (or so) similar to the other pictures taken about the TW100.
TIA
o AE100->TW100->AE300->HS10->AE500->AX100->TW700->TW3000->TW8000
Xander is offline
post #40 of 52 Old 10-07-2002, 08:59 PM
wantin'atheater's Avatar
Your excitement is contagious!! I am ready to go order a 200 myself just reading your posts, but I must be patient as I want to get reviews on the AE300 and the Sanyo LP-Z1. Maybe even the two new Sonys. You said you were going to do side-by-sides with the 300 in acouple of weeks. How so?
wantin'atheater is offline
post #41 of 52 Old 10-08-2002, 06:16 AM - Thread Starter
i know someone with a ae300 on preorder. he was that impresseed with mine. Man there is always somethng to wait and hear about. If you got a pair that clangs ya just send kaneda that yet and have some fun... I think i have said it before but sell it on ebay if you don't like it. ?? that is how i do it.
post #42 of 52 Old 10-08-2002, 08:23 AM
chromatic's Avatar
hi, :)
i would like to knkow more about the zoom modes on the ptae200 ...
with the ptae200, can you zoom a 4/3 letterbox (non anamotphic ) dvd, and still be able to see the subtitles if they are in the bottom black barre ?
thanks
chromatic is offline
post #43 of 52 Old 10-08-2002, 08:24 AM
jrwood's Avatar
What is the difference between the AE100 (discontinued) and the AE200 models?, as its an extra $300 now.
jrwood is offline
post #44 of 52 Old 10-08-2002, 09:08 AM
DRS
DRS's Avatar
Some of the differences noted so far have been:
Less screen door, better contrast, improved component input (scaler) and finally reduced fan noise. One of the most important factors that I hope is improved is the power supply (i.e. LED of death).
FWIW I think I'm going with the AE200 tomorrow (edit:then again I might wait on the SE rebadge). The price is right and screen door was never a factor for me on the ae100 and I won't be using the DVI input for at least a couple of years.
DRS is offline
post #45 of 52 Old 10-08-2002, 09:52 AM
gfly1's Avatar
Hmm, so you will not have to use a transcoder w/the 200 to achieve optimal pic quality or will you :confused:
Gfly1
gfly1 is offline
post #46 of 52 Old 10-08-2002, 11:24 AM
cpc
cpc's Avatar
Exactly. I am curious about the internal scaler/line doubler. Can I use an interlaced DVD player and just go through the component inputs and experience iscan/ae100/vga port bliss? That would be cool cause then the internal line doubler would work for my other NTSC stuff :)
cpc is offline
post #47 of 52 Old 10-08-2002, 11:36 AM
I'll make sure I try the whole range of connections when I get mine.
-Mike Lindberg-
post #48 of 52 Old 10-09-2002, 03:06 AM
scotty144's Avatar
I didn't realize that the ae200 had a line doubler?...My concerns are similar, I would like to know if the component, composite and svga inputs are improved over the 100....somehow it defeats the purpose buying a budget projector and then having to buy a htpc or transcoder to get a decent picture. I saw a ae100 demoed and was quite pleased with it, the screendoor was not an issue for me. Alot of my viewing would be done from direct tv satelite so a improved svga input would be a big plus and of course a internal doubler would be great but I am thinking that that idea may be a misunderstanding from the previous post.
JVC HD 250
Benq 1070
B&W
Onkyo
Hsu Research
scotty144 is offline
post #49 of 52 Old 10-09-2002, 05:46 AM
Yenzu's Avatar
I could be wrong here but I thought every PJ had an internal linedoubler. Most of them aren't very good though (at least not on budget PJs).
-Jens
Yenzu is offline
post #50 of 52 Old 10-09-2002, 08:53 AM
cpc
cpc's Avatar
Most PJ's do have internal line doublerss but they aren't great. The reason for using a transcoder with the AE100 was to take advantage of the VGA port and the WIDE setting which allowed the adjustment of each of the RGB settings individually. Most felt that was necessary to achieve optimum results. I can't remember if the AE100 accepted progressive through the component connections. Even if it did, the AE100 did NOT give a pixel for pixel projection like you get using the VGA port and the WIDE setting. how the AE200 works, I've no idea. Hey jeffreyoian, how about trying to look for the WIDE setting in the projector menu?
cpc is offline
post #51 of 52 Old 10-09-2002, 12:18 PM - Thread Starter
you can set it to 16:9 or 4:3 or just or zoom
i have had it setto 16:9 the entire time i have had it.
post #52 of 52 Old 10-09-2002, 03:20 PM
cpc
cpc's Avatar
Have you tried the "PC priority WIDE" setting? I believe if that is available, it is the best way to go. This requires you connect to the projector with a VGA cable. To do this you either get a DVD player with a VGA output (not many around) or you use a progressive player with a transcoder (cable which converts component to VGA) or connect an interlaced DVD player to an iScan line doubler and then connect the VGA out of the iScan to the VGA of the AE200. Just to give you some options. What DVD player are you using right now? Is it progressive or interlaced?
cpc is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
