Whats the best way to clean the lens on a pj? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-07-2002, 10:05 AM - Thread Starter
Ryan Steagall's Avatar
It seems no matter what material I use, I end up having left over lint, dust, oil, or something left on the lens after I clean it. What is the best way to clean your lens and it be perfect?
Ryan Steagall is offline
post #2 of 4 Old 10-07-2002, 10:08 AM
JPinTO's Avatar
Perhaps something like a eyeglass cleaning cloth & spray?
- JP in TOronto
JPinTO is offline
post #3 of 4 Old 10-07-2002, 10:27 AM
kthacher's Avatar
I second the idea of using eye-glass cleaning solution and the lint-free cloth used to clean glasses. I used these on my Sony 400Q (I had a condensation problem) and the results were excellent.
Kerry
kthacher is offline
post #4 of 4 Old 10-07-2002, 10:32 AM
bplemmons's Avatar
I was thinking of putting something on my lens that repels the dust, I had a spray solution for my rear projectors screen that did this wonderfully. That is made of plastic though so I don't know if It would have the same effect on glass.
BP
bplemmons is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
