Blinking Red LED, But Works Flawlessly??? - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2002, 11:13 PM - Thread Starter
Saintdog's Avatar
Should I send it back to PJ or no?
Saintdog is offline
Old 10-07-2002, 11:19 PM
Mike Lindberg's Avatar
I'd wait to see if it eventually doesn't work. No need to get worked up over something that isn't a problem yet. Edit: that is, of course, you don't have other mitigating circumstances.
-Mike Lindberg-
Mike Lindberg is offline
Old 10-08-2002, 04:56 AM
jmrobbins's Avatar
I would at least contact support and log the problem with them.
Is the lamp still in warranty?
My worry would be that it may look good or even brighter but the lamp life may be cutting in half. I assume the error detection looks at under and over voltage.
jmrobbins is offline
Old 10-08-2002, 08:03 AM
ddog's Avatar
Quoted: 35 Post(s)
How many hours are on it? how long have you owned it? those are things you need to think about, that light was put thier for a reason!
ddog!
Theater: 100 amp service, Emotiva UMC200, XPR5, XPA1 x2, XPA5, OPPO -103D, Mirage om5's x6 Lt/Rt/Ss/Bs, DefTech CLR 3000 center Earthquake Sound mini quakes x4
HotShot powered sub 2ch crossover x2,Panny 4000 PJ, 140" Fixed Screen, Harmony 900
Living room: Emotiva UMC200, XPA5,OPPO -103D, HTD HTS-1 Versa x5, Martin Logan Dynamo 700w subs x2, Aquos 70" LED
Harmony 900
ddog is offline
