Is this considered a good projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-08-2002, 10:52 AM - Thread Starter
zoothorn's Avatar
About the only good thing I came away from the Internet startup company with a few years ago was the office DLP Infocus projector. It's a model LP330. Very small. It has S-video in, component, and 15 pin from a computer. This is your typical projector used in a business environment.
I've hooked it up to my A/V receiver with the S-video and shot the picture up on a sheet and I'd have to say it looks pretty good to me. Great to have a football game with a 10' or 12' foot diagonal screen!
I'm thinking about investing in a screen that I can hang from the ceiling when I want to watch it. Anyone know anything about these projectors? How good of resolution would I be getting compared to what else is out there? One downside I can see is that when the bulb burns out it will cost me more than $400 to replace it. Is that typical?
Excuse my ignorance. I really belong in the direct view forum but thought I'd pop over here and see if I have a gem or a piece of garbage!
zoot horn rollo
zoothorn is offline
post #2 of 10 Old 10-08-2002, 11:02 AM
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
Here is a link to it: http://www.infocus.com/service/lp330/spec.asp
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is offline
post #3 of 10 Old 10-08-2002, 11:04 AM
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
I don't see a component input? Is the link the same PJ that you have?
post #4 of 10 Old 10-08-2002, 11:18 AM
ddog's Avatar
Quoted: 35 Post(s)
If you were to buy it today I'm sure you wouldn't.
650 lumens
400-1 contrast (not to bad)
1000 hr bulb life( at $400.00 can get real$$$$)
But you own it so get a screen DIY or buy and enjoy!!!!
at least you got one!! so many people out there just sitting on that fence!
ddog!
Theater: 100 amp service, Emotiva UMC200, XPR5, XPA1 x2, XPA5, OPPO -103D, Mirage om5's x6 Lt/Rt/Ss/Bs, DefTech CLR 3000 center Earthquake Sound mini quakes x4
HotShot powered sub 2ch crossover x2,Panny 4000 PJ, 140" Fixed Screen, Harmony 900
Living room: Emotiva UMC200, XPA5,OPPO -103D, HTD HTS-1 Versa x5, Martin Logan Dynamo 700w subs x2, Aquos 70" LED
Harmony 900
ddog is offline
post #5 of 10 Old 10-08-2002, 11:57 AM - Thread Starter
zoothorn's Avatar
That is indeed the projector I have. Thanks for the link. No component input is correct. It looks to be capable of 1024x768 but what would that be expressed in lines of resolution? Is that roughly the equivalant of 720p??
Sounds like it's nothing to write home about but that I wouldn't totally get laughed off the block if I set it up!
zoot horn rollo
zoothorn is offline
post #6 of 10 Old 10-08-2002, 12:05 PM
gks
gks's Avatar
I'd suggest that you rig up a PC to drive it, as S-Video has never been the best source for a PJ. If you have one handy, drop in a DVD player and a TV Tuner card, and use software to process the signal through your DB15 connector. It's an XGA projector, so I think you'd have a nice setup without spending too much.
Kevin
gks is offline
post #7 of 10 Old 10-08-2002, 12:32 PM
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
Sorry, you mentioned that it had Component inputs in your opening post so I thought I had the wrong PJ. You must have meant Composite.
I would get it running and see how it looks.
post #8 of 10 Old 10-08-2002, 12:38 PM
ddog's Avatar
Quoted: 35 Post(s)
Or you could pick up a QuadScan and do the same with no work the hassel of a pc.
ddog!
Harmony 900
ddog is offline
post #9 of 10 Old 10-08-2002, 02:06 PM - Thread Starter
zoothorn's Avatar
How much power/ram does a PC need in that situation? I have a Pentium 1 sitting around unused but I'm guessing 100mhz isn't going to do it!??!
What's a QuadScan?
zoot horn rollo
zoothorn is offline
post #10 of 10 Old 10-08-2002, 02:20 PM
ddog's Avatar
Quoted: 35 Post(s)
A QuadScan is a scaler.
You would plug your DTV, DVD, VHS, and so into it. Then using a 15pin-d plug(vga) plug it into the projector.Set the QuadScan to XGA (the native res) and your all set!
for more about the QuadScan do a search!
ddog!
Harmony 900
ddog is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
