HS10 - 1 button ARC? - AVS Forum | Home Theater Discussions And Reviews
Old 10-08-2002, 04:07 PM - Thread Starter
offshore's Avatar
Those who may have been lucky enough to see the HS10 close up at the CEDIA Expo, can you advise whether the HS10 has a 1 press Aspect Ratio Change on the remote?
I've used another projector that required getting right down into the menu system to perform an ARC, and a 1 press button should be mandatory on a HT model.
Anyone know for sure?
offshore is offline
Old 10-08-2002, 09:34 PM
jrwood's Avatar
jrwood is offline
