Sony dilemma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-09-2002, 11:47 AM - Thread Starter
Rand_alThor's Avatar
Hey all, if you could shed some light on my dilemma it would be much appreciated. With reading alot of users opinions i am really confused as to what hdtv set i should invest in. My two favorites are the sony KP43ht20 and the sony kp53hs30 43" and 53" respectively. Mainly i will use this tv for dvd playback , hockey, football and XBOX. Now here are my questions and if you have any answers i would be grateful truly:
1) will XBOX ruin a rear projection tv like this, even though its HD?
2) should i wait until this fall/winter for newer models etc?
3) does the 4:3 aspect ratio make a huge difference compared to the 16:9?
4) how does burn-in work and am i at a great risk using XBOX?
If anyone owns either of these models, do u think i need the extended future shop warranty or should the manufacturer one be suffice? I know the sales folk always try and pressure u into buying the warranty saying things like "What is this or that bulb blows up" yada yada yada. Any advice would once again be appreciated. Cheers
Rand_alThor is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
