New LG PF1500 LED Projector - AVS Forum | Home Theater Discussions And Reviews
 415Likes
post #1 of 3175 Old 01-06-2015, 07:45 PM - Thread Starter
JackB's Avatar
Quoted: 567 Post(s)
Liked: 101
Stopped in at the LG display area this afternoon and saw a new micro LED projector that looks like a winner. It's 1080P, seems about 60% the size of the PF85 which I believe it replaces, has a 1.1 zoom, and has a 1400 lumen rating. Available at Best Buy in the Feb/March timeframe. Price? $995.
The display area was not good with two other micros in the room and all white walls, floor, and ceiling so I couldn't tell just how bright and what kind of contrast, black level or color it would provide. The lever on the top was labeled zoom although the demo man thought it was for focus. I think it was zoom and you focused with the lens ring. We couldn't reach the ring so moving the lever didn't show much.
I'm definitely going to check it out when it arrives at Best Buy.
_____________________________________
Following are the settings by Esegan that I think are the best I've seen. My room is light controlled and my screen is a Da-Lite High Power with a 2.8 gain. I use the medium power setting for my viewing. The White Balance and CMS settings are:
Contrast - 97 (93)
Brightness - 48
Color - 50
Tint - 0
White Balance
Method - 2 Points
Pattern - Outer
IRE R G B
Low 0 0 0
High 4 0 -43 (Blue can to experiment on eyes from -43 to -30)
Method - 20 Points
Pattern - Outer
IRE R G B (delta e)
100) 0 0 0 (0,2)
95) -2 -1 0 (0.1)
90) -4 0 3 (0.1)
85) -1 5 5 (0.2)
80) 2 -1 2 (0.3)
75) 0 0 3 (0.2)
70) 0 1 3 (0.3)
65) 1 1 1 (0.3)
60) 1 0 1 (0.4)
55) 1 0 -1 (0.1)
50) 1 4 5 (0.3)
45) -1 0 5 (0.4)
40) 0 0 1 (0.2)
35) -3 1 1 (0.2)
30) -5 1 1 (0.4)
25) -2 0 3 (0.3)
20) -5 1 2 (0.3)
15) -5 2 0 (0.3)
10) -9 0 1 (0.3)
5) -27 6 2 (0.2)
Color Management System
patterns 75% - 75% (CIE94)
RED -11 13 13 (0.3-Delta e)
GREEN -1 8 6 (0.3)
BLUE -6 -5 -30 (1.4)
YELLOW 0 17 29 (1.8)
CYAN 29 -9 30 (0.4)
MAGENTA 6 6 -24 (0.5)
bgeery, MCaugusto, owizard and 6 others like this.
Jack
JackB is offline
post #2 of 3175 Old 01-07-2015, 04:33 AM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
Does it have a real lens?
EmmaDarknet likes this.
Verge2 is offline
post #3 of 3175 Old 01-07-2015, 05:11 AM
nasc's Avatar
Tnx for your info i will be looking forward to some detailed information about this projector as i couldn't find any info about it even on the lg website. Hopefully it uses some blether optics and the price tag in Europe doesn't top 1000 euros .
Regards.
nasc is offline
post #4 of 3175 Old 01-07-2015, 07:45 AM - Thread Starter
JackB's Avatar
Quoted: 567 Post(s)
Liked: 101
I didn't ask about the lens and will be leaving today so I won't be able to return to ask. I suspect that at a price point of <$1K it will be plastic. Maybe someone else who sees this thread will stop by and ask.
Jack
JackB is offline
post #5 of 3175 Old 01-07-2015, 10:30 AM
Robert Clark's Avatar
Quoted: 51 Post(s)
Liked: 47
Saw this projector and was impressed. Blacks are pretty good for an led and price was quoted at $999. Available February or march. I'll post pictures when I get home
Robert Clark is offline
post #6 of 3175 Old 01-07-2015, 11:19 AM
nasc's Avatar
I will be waiting for your info
Regards.
nasc is offline
post #7 of 3175 Old 01-07-2015, 11:47 AM
Liked: 1
PF85 has 1000 lumen, really are 500 on tests, so this one can get around 900, not bad. I expect improvements on focus
Cabuxo is offline
post #8 of 3175 Old 01-07-2015, 01:44 PM
Ftoast's Avatar
Quoted: 2201 Post(s)
Liked: 697
I expect it to be about the same as the pf85/87, but the price-drop and available zoom to make mounting less nerve-racking are big deals.
If there's a real-world, full-color lumen increase, that'd be amazing but I wouldn't bet on it.
I'm worried the smaller size will make it louder. The pa75u and its fatty case is impressively quiet and it's a bit spoiling.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
post #9 of 3175 Old 01-07-2015, 03:14 PM
Manamb's Avatar
Quoted: 35 Post(s)
No press release and / or specs released yet?
Manamb is offline
post #10 of 3175 Old 01-07-2015, 03:55 PM
travis_bickle's Avatar
Quoted: 13 Post(s)
1080p 3d compatibility? if so sign me in for an upgrade from my pa70g in february/march^^
travis_bickle is offline
post #11 of 3175 Old 01-07-2015, 06:23 PM
AV_Integrated's Avatar
Quoted: 1126 Post(s)
Liked: 819
Yeah, it would be nice to know if this has the 3D guts of the PF87U in it instead of being a brightness upgrade from the PF85, while dropping price, which may come at a cost of higher fan noise.
Why not put in a glass lens with decent zoom? Make sure 3D is in there? Charge a couple hundred bucks more, but make it a serious product.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #12 of 3175 Old 01-07-2015, 06:33 PM - Thread Starter
JackB's Avatar
Quoted: 567 Post(s)
Liked: 101
3D, another feature I forgot to ask about. In the P85 or P80 thread I proposed that a techie out there interested in this product should figure out how to replace plastic lens with glass one. Shouldn't be that hard or expensive.
Jack
JackB is offline
post #13 of 3175 Old 01-08-2015, 08:22 AM
nasc's Avatar
I think that LG strategic plan in video reproduction is related to AMOLED tv sets. Considering how much they have invested in this technology it is logical.
Led projectors made by LG seams almost like a side project for them , with good optics , good software and more lumen s they would compete to theirs strategic products (TV).
Technology for making good led projector is there for some time now.
What it is more strange to me that some other manufactures like Benq/Epson/Optoma.... are not presenting anything in full hd led affordable projector market.
I remember many years ago I was on the presentation of Samsung first led projector and I was thinking man this is the future :-) I was very wrong :-)
We just have to wait.
Regards.
nasc is offline
post #14 of 3175 Old 01-09-2015, 06:08 AM
DanLW's Avatar
Liked: 37
Found an article from an Italian site that at least shows us what it looks like:
http://www.dday.it/redazione/15350/l...uner-integrato
Nothing much new on specs. It is "smart" in that it has built in streaming apps, and can stream ia bluetooth. It also has a zoom lens.
The article did mention good blacks along with good color rendition.
nasc likes this.
DanLW is offline
post #15 of 3175 Old 01-09-2015, 08:51 AM
Quoted: 51 Post(s)
Liked: 47
Here are a few pics I took at CES.
ID:	468553   Click image for larger version
ID:	468561   Click image for larger version
ID:	468569   Click image for larger version
Robert Clark
post #16 of 3175 Old 01-09-2015, 10:00 AM
DanLW's Avatar
Liked: 37
I'm glad to see this coming out, along with the higher end Epson units. At least now the gap between portable LED and high-end LED is closing, and hopefully we'll see a decent quality product aimed at the $1000-$3000 home theater market announced at CEDIA this year. 2016 is when I'll be in the market again for something new, and I'd really like something LED based at around $2k so I don't have to worry about bulbs dimming/flickering/exploding...
DanLW is offline
post #17 of 3175 Old 01-09-2015, 11:32 AM
Liked: 1
No 3D, but looks great!, waiting throw ratio
Cabuxo is offline
post #18 of 3175 Old 01-09-2015, 03:37 PM
Quoted: 13 Post(s)
where do u get that info from?
i dont like the new form factor. should be much deeper in dimension, because of that. that would imply i have to reset my projector mount
post #19 of 3175 Old 01-09-2015, 11:07 PM
Manamb's Avatar
Quoted: 35 Post(s)
With a 1.1 Throw Ratio, what maximum screen size can I expect at 12 Ft?
Manamb is offline
post #20 of 3175 Old 01-10-2015, 02:39 AM
breezer001's Avatar
Hi all,
This new form factor will surely help to work silently and the optic seems to be bigger.
Can't wait to see full size and throw ratio.
breezer001 is offline
post #21 of 3175 Old 01-10-2015, 02:12 PM
Liked: 1
from Robert's pictures
i think that's the zoom, throw ratio wasn't specified
Cabuxo is offline
post #22 of 3175 Old 01-10-2015, 06:32 PM
Quoted: 13 Post(s)
the absence of 3d support at the information board is a hint but definitely not an official confirmation. especially if you consider the sloping interest or relevance of 3d in general. why wouldnt they integrate support if there last korean model already has good n easy 3d performance?
post #23 of 3175 Old 01-10-2015, 08:09 PM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
At least for my usage to hell with 3d. Don't care about Bluetooth/smart phone or other bells and whistles either. Just put the design/money into image quality/brightness. I am not ditching my PA70g until there is an LED 1080p projector with a significant quality increase in clarity/brightness, and for a decent price.
indio22 is offline
post #24 of 3175 Old 01-10-2015, 08:37 PM
thebigdaddye's Avatar
I agree I have the same projector and for the price vs overall picture to me you can't beat it. I would like to get a 1080p one but it must be worth it to me. I paid $399 for my pa70g and the picture is great on my 106 screen.
thebigdaddye is offline
post #25 of 3175 Old 01-11-2015, 01:11 AM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
I'm concerned about noise level. I can probably deal with the lumen output and lens.
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #26 of 3175 Old 01-11-2015, 07:35 AM
PENDRAG0ON's Avatar
Liked: 575
Really hoping this will finally hit the quality point I wanted from an LED projector. I've had a Sharp 70" for almost 4 years now and I am ready for an upgrade. A LED projector combined with a Slate screen was my target for an upgrade (screen would last through multiple projectors and allow gaming with a light on) Since my primary game right now is an mmo, a long life LED with quality 1080p output is a must.
PENDRAG0ON is offline
post #27 of 3175 Old 01-13-2015, 06:21 AM
Liked: 0
When you were there did you look at the PW800???? I found this picture online.. I think its called the PW800.. i tried to zoom in and I think thats what it says....
MarkTrav82 is offline
post #28 of 3175 Old 01-13-2015, 10:59 AM - Thread Starter
JackB's Avatar
Quoted: 567 Post(s)
Liked: 101
I only looked at 1080P. I think the PF1500 is the only one.
Jack
JackB is offline
post #29 of 3175 Old 01-14-2015, 05:50 AM
Liked: 0
no worries mate. The photo i posted was from 2015 CES. so maybe it was just in a different area you went to.. but no dramas.. im sure we will hear about it soon.
thanks
post #30 of 3175 Old 01-14-2015, 07:46 AM
Liked: 1
well, so LG was the only brand with PJ at the show...
need three posts more to upload a couple of pictures...
PW800 up to 1280x800 16:10, with TV tuner and 800 ANSI
Cabuxo is offline
