Mitsubishi hc3000 noise - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2015, 02:45 AM - Thread Starter
thefyn's Avatar
the noise started a year ago on startup but went away after 3 mins. Now it's constant and I presumed it's the fan, but a quick google and color wheel seemed to dominate the search.
Does anyone have experience with this? I have a new bulb Insed (the 3rd since I've owned it) and love this projector so I'd hate to scrap it.
Can the color wheel be adjusted, cleaned etc? I have no idea how to approach this outside channeling Fonzi.
Side note: writing on the forum via chrome on the iPhone, what a pain!
thefyn is offline
Old 02-22-2016, 09:15 AM - Thread Starter
thefyn's Avatar
Bump...It's getting worse. Any advice on a cheap way to fix this would be appreciated.
I presume it's this:
I see replacement ones on ebay for $100 but that seems pretty expensive. Are there any guides on how to remove and replace a faulty color wheel anywhere? I can't find much info on it.
thefyn is offline
