What pj does not need a transcoder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-28-2002, 02:26 PM - Thread Starter
Derek Swanson's Avatar
I know that with the AE series, one must use a transcoder for
component > VGA when using its HD-15 input. (excluding HTPC)
Other projectors, such as the Sony HS2, HS1, Sanyo, etc... have a
VGA input too.
Do these other projectors require a transcoder too? I am speaking
in terms of using a component > VGA cord only.
How can one tell when a transcoder is needed, and when it is not.
I am seriously looking at the sony HS2 as an alternative to the AE200.
Thanks for your thoughts on this.
Derek.
Derek Swanson is offline
post #2 of 8 Old 10-28-2002, 03:35 PM
robertmee's Avatar
The transcoder was popular for the AE-100 because
1) the resultant resolution fit the magic wide mode, matching the pixel resolution of the PJ and
2) going into the VGA port of the AE-100 gave a better picture, because as many have noted, the scaling/deinterlacing on the component inputs were lacking.
To my knowledge, I wouldn't use a transcoder on any other PJ. Most other PJ's accept component through the VGA port using a breakout cable, or have separate component inputs that are capable scalers. If you go with an XGA projector, using a transcoder would cause the PJ to have to upscale anyway, so you aren't gaining anything.
robertmee is offline
post #3 of 8 Old 10-28-2002, 05:00 PM
JPinTO's Avatar
To use the word "must" is an exaggeration. You don't "need" a transcoder for any projector.
- JP in TOronto
JPinTO is offline
post #4 of 8 Old 10-28-2002, 09:21 PM
guitarman's Avatar
Quoted: 13 Post(s)
"Other projectors, such as the Sony HS2, HS1, Sanyo, etc... have a
VGA input too."
I think what Derek really meant was, will these other PJ's sync up with a simple breakout cable to show HDTV.
The AE pany's won't sync HDTV thru VGA without the Transcoder.
Derek, I hv a NEC LT150Z, it handles all signals (HDTV) without a Transcoder thru the VGA port.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #5 of 8 Old 10-28-2002, 09:51 PM
rlindo's Avatar
Quoted: 703 Post(s)
Liked: 526
A very MINOR difference at that. At least in my experience owning one and using it for the last 4 months and now having to resort to straight component.
IMO, if transcoder/vga was 100% pq quality, straight component from the prgo scan player is about 97%. This using the Panasonic RP91 dvd player along with a 106" diagonal Da-lite HCCV screen.
rlindo is offline
post #6 of 8 Old 11-14-2002, 09:01 AM
Anthony GT's Avatar
I have a simialr question for my pj which I want to hook up soon. This is my pj:
http://tacpservice.toshiba.com/Consu.../LCD/x10ue.pdf
Page 25 shows a connection with a VGA break-out cable. Is there any way I tell from the manual if there will be a problem syncing this up as guitarman noted?
Anthony
Anthony GT is offline
post #7 of 8 Old 11-14-2002, 03:04 PM
guitarman's Avatar
Quoted: 13 Post(s)
Anthony,
You're ok with a component cable that has a VGA out on the other end.
The key info in your manual is.
"Computer connection #1, mini D-sub 15-pin Analog RGB/y/pb/pr combination.
Which means it will accept a compnent signal through it's VGA port.
Tom/guitarman
VideoDementia
post #8 of 8 Old 11-14-2002, 03:19 PM
Anthony GT's Avatar
Thanks for your help Tom!
Anthony
Closed Thread Digital Projectors - Under $3,000 USD MSRP
