Mitsubishi HC7800D or Benq W1070 ???? - AVS Forum
Old 01-12-2015, 05:09 PM - Thread Starter
gramatik2013's Avatar
Liked: 0
I have an option to get refurbished HC7800D for under $800, will this be an upgrade over Benq W1070?
Light controlled room, 100" screen, 1.3 gain.
Sports/Movies (blueray and streaming)
gramatik2013 is offline
Old 01-12-2015, 07:45 PM
rekbones's Avatar
Quoted: 71 Post(s)
Liked: 66
Should be a large upgrade if you have a dark room. That means dark ceiling, floor and walls. In a white room I would not recommend the Mits, light controlled or not.
Smart enough to know better, to old to care
rekbones is offline
