Best Factory Replacement Bulbs? - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old Yesterday, 02:03 PM - Thread Starter
kevin g.'s Avatar
Quoted: 124 Post(s)
Liked: 79
Hello all,
I am due to replace the bulb in my Planar PD7060, and am on a bit of a budget...(ain't we all?). I am looking at all the online retailers as well as Amazon, (whom I'd prefer to use). I do know enough to get the OEM bulb/manufacturer if at all possible.
The actual replacement bulb with housing is still in the 400.00 range per Visual Apex. I am seeing anywhere from 1-200 for a bare Osram bulb on Amazon, MyProjectorlamps.com, BulbAmerica, Pureland Supply, etc...
The Planar calls for an Osram 997-3443-0. Where does everyone get their bulbs? Reliable companies? How do I know I am not getting a knockoff? What should I look for? Warranty?
Thanks everyone
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is online now
post #2 of 4 Old Yesterday, 06:42 PM
Liked: 0
I bought a discount replacement bulb from Illuminex Technologies, Inc. and it works as well as the original as far as I can tell.
jflynn12 is offline
post #3 of 4 Old Yesterday, 09:23 PM - Thread Starter
kevin g.'s Avatar
Quoted: 124 Post(s)
Liked: 79
Thanks, But as I understand "discount" may not be the same as the factory uses. I have experienced this in my Samsung DLP. The aftermarket replacement was not as bright out-of-the-box...
I'm looking to make sure it is a Osram replacement...same bulb, same specs.
anybody?
post #4 of 4 Unread Today, 05:36 PM - Thread Starter
kevin g.'s Avatar
Quoted: 124 Post(s)
Liked: 79
Nobody's bought their lamps outside of their manufacturer, and can recommend a retailer??
