TW-100 component video problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-08-2002, 09:15 AM - Thread Starter
ShinJie's Avatar
Hi, there:
I just got my Epson TW-100 projector and happy that I don't have any dead pixel. However, I have problem using the component video input.
I have a Pioneer Elite DVL-919 player as my video source. The signal passed by component video shows only black and white pictures. The s-video works fine, but I can still see the screen door even from 1.5 screen width distance.
Has anybody encounter those kind of problems? My dvd player is about 2 years old and I have never tested the interlaced component video source. Maybe it's my dvd player's problem?
Thanks for your input!
-Jack
ShinJie is offline
post #2 of 4 Old 11-08-2002, 04:40 PM
MilleniumFalcon's Avatar
Jack,
Beg, borrow, or steal a different DVD player to try. Also, double check your component connections.
Jason
MilleniumFalcon is offline
post #3 of 4 Old 11-09-2002, 09:18 AM
Handi Pranadi's Avatar
Try checking wheter the PAL/NTSC is set properly. Unproper setting on this can cause a BW picture.
Bring Home The Excitement
Jakarta, Indonesia.
Handi Pranadi is offline
post #4 of 4 Old 11-14-2002, 10:41 PM
kacang's Avatar
Handi has a point, check two things :
A) the video signal selected (best usa auto in most cases) unless your Signal is PAL60 then you have to select PAL60 manually..
B) the input A can accept YCrCb or YPrPb.. and can be selected !
Erick
For TW100 issues and problems, come to
http://groups.yahoo.com/group/tw100
kacang is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
