does the ae300 have a sideshot feature? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-08-2002, 10:11 PM - Thread Starter
5thlion's Avatar
i was planning on putting it on a corner of the room.would i be able to set the pic in the middle or is that jus a sony thing?
"i swing my sword for no one"
5thlion is offline
post #2 of 9 Old 11-08-2002, 11:02 PM
suzukino's Avatar
Yes.
Suzukino
Suzukino
suzukino is offline
post #3 of 9 Old 11-08-2002, 11:10 PM
HTCrazy's Avatar
I think he means yes, its just a Sony thing.
HTCrazy is offline
post #4 of 9 Old 11-09-2002, 07:09 AM
jrwood's Avatar
The HS10 has digital keystone correction called SideShot 2 which lets you project an image from offset angles, dont forget though that while the picture be square to your screen the light wont be, and also most people hate keystone correction because usually it degrades picture quality although nobody has yet tried using this feature to see how useful it is on the HS10 (still waiting for a comprehensive review).
The AE300 only has vertical keystone correction so it has to be in line with your screen. The AE300 clone from Sanyo (PLV-Z1) has a lens shift feature which lets you actually move the projector lens up/down/left/right. This means that the image can be projected from the side and the picture/projected light will fit wherever you move the lens to.
jrwood is offline
post #5 of 9 Old 11-09-2002, 08:28 AM
Ktak's Avatar
Actually, the AE300 does have side keystone correction (digital). It's the AE200 that only has vertical keystone correction. This information comes from the Japan AE300 product brochure.
Ktak is offline
post #6 of 9 Old 11-09-2002, 10:11 AM - Thread Starter
5thlion's Avatar
KOOL IF WHAT YOU SAY IS TRUE THE AE300 IS A SUPER BUY ..I CANT WAIT :D
5thlion is offline
post #7 of 9 Old 11-09-2002, 10:42 AM
soli's Avatar
Hi,
I can confirm that the AE-300 has side keystone correction (digital), and I will never use it!!!
But at the moment it is sent return for replacement of a dead pixel :D
soli is offline
post #8 of 9 Old 11-09-2002, 11:15 AM - Thread Starter
5thlion's Avatar
does it take away from a good picture when you use this side feature?
5thlion is offline
post #9 of 9 Old 11-16-2002, 06:35 AM
suzukino's Avatar
I meant, "Yes. the AE300 has a 'sideshot' feature." But, in this case, as pointed out, it's more correctly called horizontal and vertical digital keystome correction.
Suzukino
Suzukino
suzukino is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
