How are Contrast & Brightness measured on HS10? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-12-2002, 02:03 PM - Thread Starter
ssj2's Avatar
Does anybody know how the specs have been arrived at by Sony? I'm curious as to whether the 700:1 contrast is arrived at by placing the filter on the lens, and then removing the filter to get the 1200 lumens brightness rating. Are we seeing an advertised brightness spec that can't be achieved with the use of the filter?
Steve
ssj2 is offline
post #2 of 11 Old 11-12-2002, 02:22 PM
scottpe's Avatar
I was under the impression that the "Cinema Mode" (i.e., high contrast mode) was achieved by reducing the intensity of the lamp, not with an optical filter attached to the lense. Am I way off base here guys?
--Scott
scottpe is offline
post #3 of 11 Old 11-12-2002, 02:57 PM
cashfan's Avatar
cinema mode and filter are different. I'm pretty sure 700:1 is without any filter.
cashfan is offline
post #4 of 11 Old 11-12-2002, 03:07 PM - Thread Starter
ssj2's Avatar
I just checked their spec sheet, which confirms that the 1200 lumens rating is achieved with cinema black off. Given that disclaimer, I'm guessing they would have added such a statement if the filter was required to achieve the 700:1 contrast rating.
Steve
ssj2 is offline
post #5 of 11 Old 11-12-2002, 03:19 PM
cashfan's Avatar
interesting, I would expect the specs to all be for same setting, but you may be on to something here.
cashfan is offline
post #6 of 11 Old 11-13-2002, 09:00 AM
Defiler's Avatar
According to Sony Japan's site, the HS10 is rated at 1000 lumens with Cinema Black off, and 830 with Cinema Black on.
http://www.sony.jp/products/Consumer...HS10/spec.html
I'm not sure why it's rated at 1200 lumens on other sites, and in the U.S.
Maybe these numbers are with the filter attached?
Defiler is offline
post #7 of 11 Old 11-13-2002, 09:04 AM
HTCrazy's Avatar
The local dealers have been informed that its actually 1200 ansi lumens, and all the spec sheets state that as well. So 1200 ansi lumens is the official number. All HS10 reviews so far have stated that its a very bright pj.
HTCrazy is offline
post #8 of 11 Old 11-14-2002, 08:01 PM
Chaz.ca's Avatar
1200 lumens normal
830 lumens cinema black
Possible 1000:1 Contrast ratio with filter on in Cinema Black Mode . Which Sony more than likely doesn't want to publicize due to it being the same contrast ratio as there Top of The Line VPL-12HT .
Chaz.ca is offline
post #9 of 11 Old 11-15-2002, 09:22 AM - Thread Starter
ssj2's Avatar
Chaz.ca, any idea what the lumens measurement drops to with the filter on? How did you learn of the 830 lumens in cinema black? Thanks.
Steve
ssj2 is offline
post #10 of 11 Old 11-15-2002, 10:17 AM
Defiler's Avatar
ssj: Check out the link I posted a few replies back.
Defiler is offline
post #11 of 11 Old 11-15-2002, 10:36 AM
Paul K's Avatar
That would be real sweet, if true. I'm sure there are more than a few members of this forum who possess the expertise and equipment to verify this.
Paul K is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
