Best way to clean ae300/ae200 filter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-13-2002, 08:30 PM - Thread Starter
mulveling's Avatar
Does anyone know of the best way to clean the ae300's air filter? The manual shows a picture of what I think is a vaccum cleaner attachment held up to the filter, but I'm worried this might damage the filter. Can anyone with the ae300/200 manual read this section? It seems to be written in some weird foreign language or heiroglyphics or something :D I've only run my pj for about 65 hours, but I thought I read somewhere that you should optimally clean a pj's filters every 100 hours.
Mike U.
mulveling is offline
post #2 of 7 Old 11-13-2002, 08:39 PM - Thread Starter
mulveling's Avatar
Uh-oh. This is what I get for trying to read one forum and post to another at the same time. Unfortunately it's not letting me delete this thread, so could one of the wise-and-just moderators kindly move this thread to the sub 5K forum?
Mike U.
post #3 of 7 Old 11-14-2002, 10:40 AM
Shawn O's Avatar
Moved from $5k+ forum.
Shawn
Shawn O is offline
post #4 of 7 Old 11-14-2002, 02:03 PM
rlindo's Avatar
Quoted: 703 Post(s)
Liked: 526
i have an ae100 and take the filer out and clean it with the vaccum. I sort of vaccum it through my fingers while I hold it so the actual filter does not get sucked up into it:)
Works well so far
rlindo is offline
post #5 of 7 Old 11-14-2002, 04:12 PM
proj_lvr's Avatar
When I clean the filter on my ae-100 I use one of the best methods around for really getting those filters clean. Just take the filter and run some water over it with a small amount of soap. Then take an old toothbrush and scrub it good on both sides. Make sure you rinse good and press dry with a towl or something. You don't want it to airdry or it will start to degrade over time. This method works good for me.
PC Load Letter...What the **** does that mean!?
proj_lvr is offline
post #6 of 7 Old 11-14-2002, 05:18 PM - Thread Starter
mulveling's Avatar
Thanks for the great suggestions!
I guess by the nature of your cleaning methods (vaccum, rinse & toothbrush) that these things are more resilient than I thought. I was really scared of tearing or otherwise damaging it since it looks fairly thin and flimsy.
Mike U.
post #7 of 7 Old 11-15-2002, 02:02 AM
shakti's Avatar
The user manual for NEC LT155 advises against using water or liquid of any kind to clean the filter.
shakti is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
