Davis DL450 mirror question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-14-2002, 07:22 PM - Thread Starter
hooven h's Avatar
Hello all.
I noticed that the mirror in front of the convex lens (leading to the DMD) has detiorated badly. I'm wondering if it's possible to replace it w/ an ordinary mirror of the same size.
hooven h is offline
post #2 of 2 Old 11-15-2002, 08:23 AM
odskaggs2's Avatar
I believe the mirrors used are called first surface mirrors. Also don't forget the heat factor if you choose a mirror replacement
odskaggs2 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
