What size mounting bolts for AE300? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-15-2002, 05:46 AM - Thread Starter
paulluse's Avatar
I want to mount my new AE300 underneath a shelf behind my couch, but I'm not sure what size bolts will fit in the screw holes on the bottom of the projector... Does anyone know what size I should buy? I want to pick some up and the shelf materials on my way home from work today.
Paul
paulluse is offline
post #2 of 2 Old 11-15-2002, 06:23 AM
Rick Waller's Avatar
Metric M4x4 screws, Most hardware stores carry metric fasteners.
But please be carefull and make sure that the screws will not be too long.
Others have contacted or damaged the circuit boards.
Guage the holes with something like a toothpick to see how close the circuit boards are.
Rick
Rick Waller is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
